Compile error_AQM
I am upgrading the new software and had no problems with the Tx and Rx but got the following error when upgrading the AQM
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_830678 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_279609 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\WeatherDuino_AirQualityMonitor_v8.0_b001.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_830678 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_279609 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\WeatherDuino_AirQualityMonitor_v8.0_b001.ino
Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHCRC.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHDatagram.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericDriver.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericSPI.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHHardwareSPI.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHMesh.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHReliableDatagram.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHRouter.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSPIDriver.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_CC110.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_E32.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_MRF89.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF24.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF51.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF905.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF22.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF24.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF69.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF95.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_TCP.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\FastIO.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\I2CIO.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LCD.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_I2C.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_I2C_ByVac.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SI2C.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR1W.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR2W.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\LiquidCrystal_SR3W.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\utility" "C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5\SI2CIO.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Event.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Timer.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\SHT21\SHT2x.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\HTU21D\HTU21D.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp.o"
C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\WeatherDuino_AirQualityMonitor_v8.0_b001.ino: In function 'void setup()':
WeatherDuino_AirQualityMonitor_v8.0_b001:275: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
    lcd.begin();
C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\WeatherDuino_AirQualityMonitor_v8.0_b001.ino:275:15: note: candidate is:
In file included from C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\WeatherDuino_AirQualityMonitor_v8.0_b001.ino:39:0:
C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:110:17: note: virtual void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
   virtual void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS);
C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:110:17: note:   candidate expects 3 arguments, 0 provided
C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\LCD.ino: In function 'void init_LCD()':
LCD:22: error: call of overloaded 'write(int)' is ambiguous
    lcd.write(0);
C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v8.0\software\WeatherDuino_AirQualityMonitor_v8.0_b001\LCD.ino:22:16: note: candidates are:
In file included from C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LiquidCrystal_I2C.h:35:0,
C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5/LCD.h:521:19: note: virtual size_t LCD::write(uint8_t)
   virtual size_t write(uint8_t value);
In file included from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232,
                from C:\Users\JBA\AppData\Local\Temp\arduino_build_830678\sketch\WeatherDuino_AirQualityMonitor_v8.0_b001.ino.cpp:1:
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:52:12: note: size_t Print::write(const char*)
    size_t write(const char *str) {
Multiple libraries were found for "LiquidCrystal_I2C.h"
Used: C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5
Not used: C:\Program Files\Arduino\libraries\Newliquidcrystal_1.3.5
Using library RadioHead in folder: C:\Users\JBA\Documents\Arduino\libraries\RadioHead (legacy)
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Using library Newliquidcrystal_1.3.5 in folder: C:\Users\JBA\Documents\Arduino\libraries\Newliquidcrystal_1.3.5 (legacy)
Using library Timer in folder: C:\Users\JBA\Documents\Arduino\libraries\Timer (legacy)
Using library Adafruit_SHT31 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31
Using library SHT21 in folder: C:\Users\JBA\Documents\Arduino\libraries\SHT21 (legacy)
Using library HTU21D in folder: C:\Users\JBA\Documents\Arduino\libraries\HTU21D (legacy)
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
exit status 1
Hi Jim,
Software compiles just fine. Checked many times.
It seems that your fight with the LiquidCrystal library still isn't solved... Smile
