RS Fan config.
Hello, I wonder if someone can help me please.
I have upgraded my Weatherduino pro plus to v4.0.
However I now find that my RS Fan is running continuously.
I wonder if I am missing a new config setting somewhere?
On the receiver it is showing OFF all the time.
This is what I have it set as:
#define FanControlSensor  0      // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan)
#define fanOn_HiTemp     20      // RS Fan turn on when outside temperature is >= than this value (ºC)
#define fanOn_LowTemp     2      // RS Fan turn on when outside temperature is <= than this value (ºC)
#define fanOn_LowWind     1      // RS Fan turn on when Wind Average is <= than this value (m/s)
Everything else is working fine.
Regards Derek
Hi Derek,
Could you please post your entire Config_TX.h file?
Thank you
PS: When posting code, please use the code tag (see icons on the editor toolbar)
Hello Werk, many thanks for the reply.
Here is the Config_TX.h file.
Regards Derek
// -------------------------------------------------------------------------------------- //    WeatherDuino Pro2 Universal TX - Version: 4.0 b002 //           Start of user configurable options // -------------------------------------------------------------------------------------- // -------------------------------------------------------------------------------------- //   Define ID and TX unit number // -------------------------------------------------------------------------------------- #define StationID  0xA1    // Must be equal to your RX Unit (Value from 0x00 to 0xFF)  #define UnitID        0    // If you use only one TX unit define it as UnitID = 0                            // For a second TX unit, define it as UnitID = 1 // -------------------------------------------------------------------------------------- //   Define type of Temperature / Humidity sensor used as Sensor 0 and / or Sensor 1 // -------------------------------------------------------------------------------------- #define TH_Sensor0  0      // [SENSOR 0] - 0 for SHT2x sensor, 1 for SHT31 sensor, 2 for HTU21 sensor, 9 for Not Used #define TH_Sensor1  9      // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used // -------------------------------------------------------------------------------------- //   Define which Temp / Hum sensor controls the fan, and threshold values // -------------------------------------------------------------------------------------- #define FanControlSensor  0      // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan) #define fanOn_HiTemp     20      // RS Fan turn on when outside temperature is >= than this value (ºC) #define fanOn_LowTemp     2      // RS Fan turn on when outside temperature is <= than this value (ºC) #define fanOn_LowWind     1      // RS Fan turn on when Wind Average is <= than this value (m/s) // -------------------------------------------------------------------------------------- //   Define type of Wind Speed sensor. See below for allowed types // -------------------------------------------------------------------------------------- /*  --- Fine Offset Anemometers ---  Use 1O for standard FO anemometers  Use 11 for FO anemometer modified with 1 hall effect sensor  --- Inspeed Anemometers ---  Use 20 for Inspeed Vortex, digital 8 pulse revolution anemometer  Use 21 for Inspeed Vortex, hall efect sensor  Use 22 for Inspeed Vortex, read switch sensor    --- Davis Anemometers ---  Use 30 for Davis 6410, 7911 anemometer    --- Novalynx Anemometers ---  Use 40 for Novalynx, model 200-WS-02F  --- Environmental Measurements Limited ---  Use 50 for EML, model WSD1  --- Didcot Instrument Company ---  Use 60 for DIDCOT, model DWR205  --- Vector Instruments ---  Use 70 for Vector Instruments model A100LK  Use 71 for Vector Instruments model A100L2  Use 72 for Vector Instruments model A100R */ #define WSpeedSensor_Type 10             // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- //   Define type of Wind Direction sensor // -------------------------------------------------------------------------------------- /*  --- Fine Offset Wind Vane ---  Use 1O for standard FO wind vane    --- Analogue Wind Vanes ---  Use 20 for any 5V analogue wind vane. See bellow for a list of tested models - Inspeed E-Vane 2 - Davis 6410 - Novalynx, model 200-WS-02F - Environmental Measurements Limited, model model WSD1 - DIDCOT, model DWD205 - Almost all 5V analogue wind vanes will work */ #define WDirSensor_Type  10  // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- //          Analogue Vane Offset Calibration // -------------------------------------------------------------------------------------- #define WDir_offs        0   // Usally there is no need to change default value (zero) // -------------------------------------------------------------------------------------- //   Define Rain Gauge tip boucket value (mm) // -------------------------------------------------------------------------------------- /*   Use 0.280 for standard FineOfset rain gauges (Datasheet value = 0.2794)   Use 0.200 for standard metric Davis rain gauges   Use 0.254 for standard imperial Davis rain gauges */  #define COLLECTOR_TYPE  0.280  // Please note: Values must be in metric units. Max. resolution: 3 decimal digits    // -------------------------------------------------------------------------------------- //   Define type of UV Sensor // -------------------------------------------------------------------------------------- #define UV_Sensor  9      // 0= UVM-30A, 1= VEML6075, 9= Not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Enable Disable // -------------------------------------------------------------------------------------- #define SoilLeaf_Interface     0   // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface #define Number_AnalogSensors   2   // Up to 4 analog sensors // -------------------------------------------------------------------------------------- //   Define which data this unit will send. 0 = Not send this data, 1= Send this data // -------------------------------------------------------------------------------------- #define ID0  1  // Temp/Hum Data #define ID1  0   // Not Used #define ID2  1   // Wind data #define ID3  1   // Rain data #define ID4  0   // SolRad / UV data #define ID5  1   // Hardware Status - System Temp, Battery Voltage etc #define ID7  0   // Send Soil & Leaf Temperature Data #define ID9  0   // Send Soil & Leaf Moisture / Wetness Data // -------------------------------------------------------------------------------------- //   Hardware settings // -------------------------------------------------------------------------------------- // SHT31 I2c Address // Default address will work most of the times! #define SHT31_address 0x44           // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Debug // -------------------------------------------------------------------------------------- #define Debug_Enable      false #define DebugID0          false #define DebugID2          false #define DebugID3          false #define DebugID4          false #define DebugID5          false #define Easyweather_Test  false #define Debug_SLinterface false // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
Hello Derek,
Everything in your config_TX.h file seems OK.
Can you please check two things:
- Is the FAN led on?
- Check if the negative wire of the fan is connected to where says -9V and not to any GND point. If the negative wire of the fan is connected to GND the fan will be always ON.
Thank you
Hello Werk
When you asked if the fan led switched on , I suddenly realised what I had done.
For ages I have had the fan connected to the led connection, not to the 9v+ and _ ones.
Not bothering with an led, so I did not realise my mistake.
It has been working fine until recently though.
I will now correct it.
Many thanks for showing me the light.
I feel such a fool, but I can put that down to age.
Best Regards Derek
Congratulations!
Remember that the description of your mistake can help someone else not to let it.  Smile
