Threads: 27
Weather Station: Alma, MI USA
Country:
Just received the first rainfall with my new 8" rain gauge. Cumulus MX recorded 0.25" of rain and the Pro2+ receiver is showing 0.20".
TX1 is set for Collector_Type 0.254 for a bucket tip of 0.01".
CumulusMX multiplier is 1.27
Did I miss a setting somewhere?
TIA
Threads: 27
Country:
29-09-2017, 11:06
(This post was last modified: 29-09-2017, 11:07 by
danner.)
With a multiplier in CumulusMX of 1.27, 0.20" of rain comes out to 0.254" or rounded to 0.25". So the question is which figure is correct? The 0.20" displayed on the Pro2+ console or the 0.254" in CumulusMX?
Unfortunately I don't have a manual rain gauge, but we received a little more rain since my first post. My Ambient Weather station currently says 0.23", the Pro2+ says 0.22", and Cumulus says 0.28".
If the Pro2+ reading is correct then the multiplier in CumulusMX should be set to 1.
Threads: 27
Country:
I did a search over on the cumulus forum and Steve said "If you set a multiplier, Cumulus will read the rate from the station and apply the multiplier to it." So when the WeatherDuino communicates with cumulus it tells it each tip is 0.254mm and cumulus then applies a 1.27 multiplier, because that's what I have set. If that's the case then the multiplier should be 1.00 not 1.27. Do I have that right?
Threads: 336
Country:
I'm working on this on the last 4 hours, and we may have here a great problem... I still haven't many answers, but up to now I discovered that Cumulus MX works differently than Cumulus 1, on my tests (and in my live site too) I only use Cumulus 1, this is why I had never noted this possible issue, that only happens when the user sets CumulusMX to use Inches.... If the thing is what I'm thinking, that will be very difficult to solve... Contrary to Cumulus 1 which reads the type of rain gauge (metric or imperial, in our emulation always metric) from the station eeprom, Cumulus MX seems to automaticaly assume the type of the rain gauge (metric or imperial) from the type of units selected by the user.
With Cumulus 1, everything is working fine.
Lets see if I will be able to find a universal solution for this.
