Software Configuration
Hi
I am setting up the software for my weather station and its asking for my location in tenths of degrees.
Would anyone be able to tell me how I convert my Lat/Long location in to tenths of degrees
The easy way:
https://data.aad.gov.au/aadc/calc/dms_decimal.cfm
or harder way;
http://mathforum.org/sarah/hamilton/ham.degrees.html
(10-09-2017, 11:07)garybb1 Wrote:  Hi
Hi garybb1,
I think the easiest way is to turn Google Maps on and right-click on your position:
[Image: position-sm.png]
Thanks for your replies
I have found my Lat/Long coordinates from google maps and have them in both normal format and DMS format, I am unsure as to how to convert this format to tenths of degrees as requested by the software.
Sorry if I am missing something simple.
(11-09-2017, 09:31)garybb1 Wrote:  Sorry if I am missing something simple.
Smile
One sometimes worries about the problem that is possible for someone else's simple.
But that is why there is a forum and the rest of us ...
(11-09-2017, 09:31)garybb1 Wrote:  I am unsure as to how to convert this format to tenths of degrees as requested by the software.
I will try to give an example for a place that I think its not far from you:
Basingstoke - Victory Roundabout: 51.266, -1.092
For a location like that you should use on the software: 512, -109 (always integers)
Thank you
It now makes complete sense to me
Shouldn't that be 512,  -10 , or rounded to the nearest integer   513, -11  ?
IMHO the easiest method to convert DMS to tenths of Degrees is to multiply the Degrees by 10 and add the number of Minutes divided by 6, i.e  D * 10 + M / 6.  The seconds can be ignored (too small to bother with).
The most common mistake is to forget the minus sign for the Western hemisphere, particularly for USA.
Cheers,  Alan.
(11-09-2017, 19:43)AllyCat Wrote:  Hi,
Smile Smile
In CZ we have a proverb: even a master carpenter is going to die!  Smile
(This translation is very bad, but maybe it's a little bit ...)
(11-09-2017, 19:43)AllyCat Wrote:  Shouldn't that be 512,  -10 , or rounded to the nearest integer   513, -11  ?
Yes, it should! Thanks
garybb1, please correct the longitude value.
