tobyportugal
Unregistered
Good evening,
To excuse my question, I do not know well (0/10
) the WeatherDuino software.
Which is the time (sec) of transmission between the TX/RX?
For you help to understand my question: Davis VP2 transmits to the console the data “wind” all the 2,5sec.
Thank you, good evening.
tobyportugal
Unregistered
(12-08-2017, 00:51)Werk_AG Wrote: (07-08-2017, 21:16)tobyportugal Wrote: Which is the time (sec) of transmission between the TX/RX?
Wind data is sent each 3 seconds.
With 3 sec, Ultrasonic seems to me an expenditure unjustified.
A track for the future: - > 1sec
Good weekend with all
http://www.meteo-la-rochelle.fr/comparai...metres.php
Threads: 0
Weather Station: Fine Offset (various)
Country:
It's important to remember that 434 MHz is a shared radio frequency, used by many other commercial systems (I have nearly 10). The typical transmission period for "repetitive" systems (temperature senders, etc.) is one minute, or much longer for wireless doorbells and garage door openers, etc. So 3 seconds is already rather fast and 1 second would probably "kill" most of the other available systems, because of all the "collisions" between data packets from different sources.
But of course the "transmission" and "measurement" times do not need to be the same. The humble "Fine Offset" weather stations transmit only once every 48 seconds, but the data packet contains an "average" wind value (obviously over the 48 seconds period) and a "gust" value, which is the maximum of 24 values measured in two-second intervals.
I don't know how the Weatherduino data/protocol is organised, but obviously a (separate) "gust" value would allow the transmitter to calculate a (maximum) value over as small a period as desired (or at least practical).
tobyportugal
Unregistered
Thank you with you two for your explanations, with IMTRANSLATOR I have +/- understood.
The solution passes by one dated logger XD-05.
I will start with the beginning: to make function “normal” WeatherDuino.
Good Sunday.
Threads: 337
Country:
Toby
I think that we are trying to say that for the general purpose of a weather station there is absolutely no need to do gust readings at 1 second intervals.
Some time ago when I started with the WeatherDuino system, I did several experiments to try to determine what should be, or what could be the best interval to do wind gust readings.
Interestingly, I remenber that doing gust readings at intervals of 1 second always produced lower readings (also produced more flat graphics) than when the readings are done at intervals of 2 to 3 seconds.
Anyway, as Alan said, one thing is the "transmission" time another one is the "measurement" time. In the case of WeatherDuino, both are 3 seconds.
tobyportugal
Unregistered
(13-08-2017, 06:48)Werk_AG Wrote: Toby
Yes, I understood and I know standards WMO.
I have a VP2 to standards WMO
http://www.infoclimat.fr/observations-me...ghlight=05
The relief at home is particular with winds which come from the valley by going up (it is very particular on the left with 100m or on the right there is more this phenomenon.
If you look at the comparative one on MéteoCaldas, you will see that the direction of the winds at home is often different.
I simply seek to understand this phenomenon at home.
Threads: 0
Hey guys,
I occasionaly found your topic discussed here.
We recently developed a cheap ultrasonic anemometer only cost 380 USD/UNIT.
HY-WDC2DVSE Ultrasonic Wind Vane Anemometer
Compatible with Davis Vantage Pro2 Equipment
Our website:
www.hongyuv.com/en
My email: stefan@hongyuv.com
Contact me if you have any interest.
