Problems with system info screen
Hi.
I have built the RX+ board and have it working, but I have problem with the "system info " screen
it is showing the following headings  :
Tx battery voltage :
Tx case temp         :
Rs fan state            :
Tx packets 24hr     :
Rx packets 24hr     :
Rf efficincy              :
But there are no readings.
I am using RX+ v2.06 b018 software
I think that I have configured the software wrong ie the part about extra sensors, as I beleive that the, battery voltage and Tx case temp are  classed as extra sensors.
If I am correct, could please show they should be configured in the software.
Also how do you get the readings for the Tx, Rx packets and Rf efficiency ?
regards
tyntop
Hi tyntop,
The most probable cause for the described issue is that you may have forgot to upgrade the software of your TX units, or just haven't enabled this setting on the TX software:
#define ID5  1   // Hardware Status - System Temp, Battery Voltage etc
Quote:I think that I have configured the software wrong ie the part about extra sensors, as I beleive that the, battery voltage and Tx case temp are  classed as extra sensors.
No more in the Pro2 PLUS.
Hi Werk,
I did'nt think of that, as I have'nt upgraded the TX software yet.
I will try that over next couple days.
thanks again
tyntop
Ok, then please report back.
Reporting back as requested I managed to update the TX software today, werk you was right with your assessment my system info  is now on screen.
thankyou
regards
tyntop
Smile
Thank you too.
Users browsing this thread:
