Threads: 3
Country:
I'm thinking of replacing the TX and RX modules for 433MHz with 868MHZ modules.
From what I can see in the datasheet the 433 MHz modules use ASK, OOK is it possible to use FSK instead?
Threads: 336
Country:
Hi, welcome
Sorry, FSK modulatin is not supported.
Threads: 3
Country:
Thank you very much Werk_AG.
What's the datarate for the ASK modulation and the duty cycle of the transmitter?
Threads: 336
Country:
The system uses OOK modulation, which is a variation of ASK.
The baud rate used is 1000bps.
Not sure about what you want to know about the transmitter duty cycle, but if you are referring about the time interval between each data packet, it is variable.
