AQI upload issue
I am trying to get my AQI set up and get the following error when uploading v 6.0, any ideas please
Arduino: 1.8.2 (Windows 10), Board: "Arduino Nano, ATmega328"
Sketch uses 16720 bytes (54%) of program storage space. Maximum is 30720 bytes.
Global variables use 1106 bytes (54%) of dynamic memory, leaving 942 bytes for local variables. Maximum is 2048 bytes.
avrdude: verification error, first mismatch at byte 0x0000
         0x00 != 0x0c
avrdude: verification error; content mismatch
option enabled in File -> Preferences.
Jim, try upgrading the IDE to 1.8.3.
(09-10-2017, 08:11)uncle_bob Wrote:  Jim, try upgrading the IDE to 1.8.3.
Bob,
Same result!!
Arduino: 1.8.3 (Windows 10), Board: "Arduino Nano, ATmega328"
Sketch uses 16742 bytes (54%) of program storage space. Maximum is 30720 bytes.
Global variables use 1120 bytes (54%) of dynamic memory, leaving 928 bytes for local variables. Maximum is 2048 bytes.
         0x00 != 0x0c
Are you seeing the nano (CH340) appear in the Device manager when you plug it in?
Maybe turning verbose logging on may throw some more light on it.
(09-10-2017, 09:18)uncle_bob Wrote:  Are you seeing the nano (CH340) appear in the Device manager when you plug it in?
Here is the result
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10803 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_109150 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_930730 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v6.0\software\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10803 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_109150 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_930730 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_AirQualityMonitor\v6.0\software\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\VirtualWire\VirtualWire.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Event.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Timer.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\SHT21\SHT2x.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\HTU21D\HTU21D.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o "nul" Generating function prototypes... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\preproc\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp.o" Compiling libraries... Compiling library "VirtualWire" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\VirtualWire\VirtualWire.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\VirtualWire\VirtualWire.cpp.o" Compiling library "Wire" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Wire\Wire.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Wire\utility\twi.c.o" Compiling library "LiquidCrystal-I2C" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp.o" Compiling library "Timer" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Event.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Timer\Event.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Timer\Timer.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Timer\Timer.cpp.o" Compiling library "Adafruit_SHT31" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp.o" Compiling library "SHT21" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\SHT21\SHT2x.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\SHT21\SHT2x.cpp.o" Compiling library "HTU21D" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\JBA\Documents\Arduino\libraries\HTU21D\HTU21D.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\HTU21D\HTU21D.cpp.o" Compiling library "SoftwareSerial" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\VirtualWire" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\SoftwareSerial\SoftwareSerial.cpp.o" Compiling core... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_pulse.S.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WInterrupts.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\hooks.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\hooks.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_analog.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_digital.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_digital.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_pulse.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\wiring_shift.c" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_shift.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\CDC.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\CDC.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial0.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial0.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial1.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial1.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial2.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial2.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial3.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial3.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\IPAddress.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\IPAddress.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\PluggableUSB.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\PluggableUSB.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Print.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Print.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Stream.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Stream.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\Tone.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Tone.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\USBCore.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WMath.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WMath.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\WString.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WString.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\abi.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\abi.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\main.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\main.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\new.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_pulse.S.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WInterrupts.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\hooks.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_analog.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_digital.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_pulse.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\wiring_shift.c.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\CDC.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial0.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial1.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial2.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\HardwareSerial3.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\IPAddress.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\PluggableUSB.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Print.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Stream.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\Tone.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\USBCore.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WMath.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\WString.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\abi.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\main.cpp.o" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\core.a" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\core\new.cpp.o" Archiving built core (caching) in: C:\Users\JBA\AppData\Local\Temp\arduino_cache_930730\core\core_arduino_avr_nano_cpu_atmega328_5638c217b04eda8279099c4937887265.a Linking everything together... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\sketch\WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\VirtualWire\VirtualWire.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Wire\Wire.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Wire\utility\twi.c.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Timer\Event.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Timer\Timer.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\SHT21\SHT2x.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\HTU21D\HTU21D.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150\libraries\SoftwareSerial\SoftwareSerial.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/core\core.a" "-LC:\Users\JBA\AppData\Local\Temp\arduino_build_109150" -lm "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.eep" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex" Using library VirtualWire in folder: C:\Users\JBA\Documents\Arduino\libraries\VirtualWire (legacy) Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire  Using library LiquidCrystal-I2C in folder: C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C (legacy) Using library Timer in folder: C:\Users\JBA\Documents\Arduino\libraries\Timer (legacy) Using library Adafruit_SHT31 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31  Using library SHT21 in folder: C:\Users\JBA\Documents\Arduino\libraries\SHT21 (legacy) Using library HTU21D in folder: C:\Users\JBA\Documents\Arduino\libraries\HTU21D (legacy) Using library SoftwareSerial at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial  Sketch uses 16742 bytes (54%) of program storage space. Maximum is 30720 bytes. Global variables use 1120 bytes (54%) of dynamic memory, leaving 928 bytes for local variables. Maximum is 2048 bytes. C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex:i  avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53          Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/          Copyright (c) 2007-2014 Joerg Wunsch          System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"          Using Port                    : COM6          Using Programmer              : arduino          Overriding Baud Rate          : 57600          AVR Part                      : ATmega328P          Chip Erase delay              : 9000 us          PAGEL                         : PD7          BS2                           : PC2          RESET disposition             : dedicated          RETRY pulse                   : SCK          serial program mode           : yes          parallel program mode         : yes          Timeout                       : 200          StabDelay                     : 100          CmdexeDelay                   : 25          SyncLoops                     : 32          ByteDelay                     : 0          PollIndex                     : 3          PollValue                     : 0x53          Memory Detail                 :                                   Block Poll               Page                       Polled            Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack            ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------            eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff            flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff            lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00            hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00            efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00            lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00            calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00            signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00          Programmer Type : Arduino          Description     : Arduino          Hardware Version: 2          Firmware Version: 1.16          Vtarget         : 0.0 V          Varef           : 0.0 V          Oscillator      : Off          SCK period      : 0.1 us avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f (probably m328p) avrdude: reading input file "C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex" avrdude: writing flash (16742 bytes): Writing | ################################################## | 100% 4.86s avrdude: 16742 bytes of flash written avrdude: verifying flash memory against C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex: avrdude: load data flash data from input file C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex: avrdude: input file C:\Users\JBA\AppData\Local\Temp\arduino_build_109150/WeatherDuino_AirQualityMonitor_PMS_v600_b004_03102017.ino.hex contains 16742 bytes avrdude: reading on-chip flash data: Reading | ################################################An error occurred while uploading the sketch ## | 100% 3.67s avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0000          0x00 != 0x0c avrdude: verification error; content mismatch avrdude done.  Thank you.
I'm no expert on Arduino but is the AQM actually working? As it seems to have been written to successfully but is failing the reading check.
I would try to shut down AQM, remove Arduino Nano, load a program to it, and then install back into AQM.
You also tried to compile only first, ie. without recording?
(09-10-2017, 11:57)Barrow4491 Wrote:  Here is the result
Hi Jim,
When posting code on the forum, please use the "code" tag, otherwise its almost impossible read it.
The issue you are facing doesn't seem a problem with the AQM code, as it compiles fine.
It can be a problem with the USB cable, or be related to a possible bug in the Arduino IDE, where under some circumstances the code upload fails.
May there is a workaround...
Please post your AQM config file
Hi Jim,
I swapped out the Nano and it compiled and uploaded OK. I powered the unit up but nothing seems to happen but I an unsure of what is supposed to.
Could you give me a brief outline of the procedure I should expect.
my config file is attached
//   WeatherDuino - Air Quality Monitor v6.00 b004
//                  User Configurable Options
//   Define ID and TX unit number
#define StationID  0xA1      // Must be equal to your RX Unit (Value from 0x00 to 0xFF)
//   Define PMS7003 data set
#define PMS7003_dataSet 1    // 0= CF1, 1= Ambiente (You should always use this data set)
#define use_RHcomp      1    // 1= Use RH compensation, 0= disabled
//   Define if CO2 sensor is installed
#define Use_CO2 1            // 0= Not instaled, 1= Instaled
//   Define type of Temperature / Humidity sensor
#define TH_Sensor 1          // 1= HTU21D, 2= SHT2x, 3=SHT3x
//   Enable / Disable RF data transmission
#define TX_Mode  1           // 0= No data will be transmitted via RF, 1= Transmit Data
//   Enable / Disable Display
#define LCD_Display 1        // 0= Disable Display, 1= Enable Display
//   Enable / Disable PMS7003 sensor Debug on Serial Monitor
#define Debug_PMS7003 0      // 0= Disable 1= Enable
//   Enable / Disable CO2 sensor Debug on Serial Monitor
#define Debug_CO2     0      // 0= Disable 1= Enable
//   SHT31 I2C Address - Default address will work most of the times!
#define SHT31_address 0x44       // Default value is 0x44, but it can be changed to 0x45
Hi Jim
According to your config file, you are using an LCD. Is it displaying anything?
Also check if the type of the temp / hum sensor is correct.
Enable the debug options, and open the serial monitor at 19200 baud. Its always good leaving the system running some hours with the debug options active. You should see something in the serial monitor.
