Hi JT118,
I'm glad that you bring this theme to the public forum, some time ago I tried launch a discussion about this matter on the Developers forum, however without success...
Quote:Looking to the data of my CO2 graphs, "apparently" they seem wrong... Initially I expected a more constant reading. We read everywhere that the CO2 median levels on the earth are around 400ppm. So what's going on?
I'm sure that you are the most capable person to investigate about this matter, and bring us a well written explanation.
It a fact that the mean CO2 value on earth is a value around 400 ppm, however this value is a global value, and local measures, depending on location and time of the day may vary greatly.
I already have searched a lot abbout this matter, and it seems that our readings are not so wrong as it seems at first sign.
If you carefully look at my readings, you will see that the variations follow a pattern: during the day (when there is light), they are always close to 400ppm, and start to increase at the end of the day, lowering again during the next day time.
Googling for it, I found on the internet many explanations to this behaviour. All of them refer that this behaviour is related to the photosynthesis process, so its possible that all of us that live in densely arborized zone will got high CO2 readings at night.
... in the absence of light there is no photosynthesis, when the photosynthesis process can't happen, the plants release more CO2 (at night they are only breading, just like us)
I'm counting with you to further investigations on this matter.
A special note regarding the MH-Z19:
* The minimum reading is 400ppm
* It is factory calibrated, but also allows calibration, however it should not be done, unless you can do it in an environment where you know exactly the CO2 level
