Threads: 13
Weather Station: pro2+
I soldered everything to be sure that the contacts are frank, the screen always remains white.
I will now just desolder and test with a normal mega arduino. If this does not work, it will be one of the CMS ICs that is failing.
An 9V 3A power supply is use for powered the Pro2 PLUS
Threads: 13
I want to try to connect the arduino in place of the meduino, no risk?
i think there is a logic level converter is out of order. Sometimes an IC can be fails.
Yes a fault IC can happen, but that would be my last suspect.
My first suspects are always cables and connections. Surely you know, but cables for SPI connections should always be very short, more than 10 to 15 cm not always work
Threads: 7
Weather Station: Morgenster Heights, Cape Town
I had a similar issue when I had a faulty sensor.
The faulty sensor would cause the entire I2C bus to hang, not allowing any of the other I2C devices to talk.
As soon as I removed the faulty sensor the I2C bus responded.
You could also try and load I2C scan program on the arduino to check that all the I2C devices are picked up on the network and the addressing is the same as defined in the WeartherDuino software.
Threads: 13
I'm going to buy a hot air soldering, this will be useful to desolder the 2 ICs, I need it for other projects next.
Can you send me the 45DB011D-SSH and the 74AHC244DW?
I don't see any other components used to generate the display. I find them on the internet but not at the same reseller and the shipping costs become too high.
I'll pay them.
thanks
You can try to discard the possibility of a problem with the flash memory (45DB011D-SSH) running the Flash_Memory_test utility included in the software package. If you get anything than zeros on the serial monitor, it means that the memory chip is working properly as also the SPI bus. However if the problem is with the SPI bus, this test can be inconclusive.
Let me know the results.
Regarding to send you the two IC's, I have sent you a PM.
Could you please post a close picture of the connections, both on the TFT and board side.
