  • 5 Vote(s) - 4.2 Average
WeatherDuino Pro2 'PLUS' Build
#61
I that case you only need to set the collector type as described above.
Thanks WErk...I have done that now
So now to the testing while I get my enclosures etc organised. I extended the cables from the Davis temp/humid sensor and the rain gauge as I will have the sensor pack on the roof of my hangar and run cables down to the inside of the hangar. This is where the TX unit will be so its out of the weather. The battery backup I will connect the unit to my solar charging setup I have for all my tractors and vehicles. I have a 190W grid connect panel on the roof and that goes to a MPPT solar charger. The battery side goes to a 5 way fuse rack and off each fuse I have a lead running over to 3 tractors a old farm hilux 4wd and a diesel generator. This essentially connects all of the batteries together so they keep each other charged although they will self discharge each other doing this but it is very minimal overnight,  and the solar charger then charges them all at whatever rate the batteries in each need. Then they get to float at around 13.6V. I will power the TX from this source that way I can monitor the battery system volts from over in the house and can keep an eye on the voltage at all times.
Can this battery data be fed somehow to Wunderground so it comes up on the page?
So my sensor pack is outside here seeing how it all goes until I get the boxes made for the WD and the RX and the TX unit
Mark
I'm pretty certain that WU doesn't record or display battery voltage.
To see that you will a webserver to upload it to.
Yes I have been going around the site now its all running on there but doesnt look like you can add anything IBRISBAN97 is the station here at home while testing but it wont end up here
I'd like to show, how it is possible to translate or customize the RX+ display (color, string long, ...).
A few more notes:
- This is the software version that is yet betas
- Translated not 100% all of them, only the "important" items
- My RX+ unit is in a state of construction, so some of the sensors still do not show the real value
- These adjustments are only to users when software upgrades are lost
- A single post can fit up to 6 images, so it is divided into two posts
[Image: DSC_6983-upr-sm.jpg] [Image: DSC_6984-upr-sm.jpg] [Image: DSC_6985-upr-sm.jpg]
[Image: DSC_6986-upr-sm.jpg] [Image: DSC_6987-upr-sm.jpg] [Image: DSC_6988-upr-sm.jpg]
[Image: DSC_6989-upr-sm.jpg] [Image: DSC_6990-upr-sm.jpg] [Image: DSC_6991-upr-sm.jpg]
[Image: DSC_6992-upr-sm.jpg]
Looks cool Zdenek Smile
Cool
(24-02-2017, 09:49)hornychz Wrote:  A few more notes:
As stated, the above images are from screens of the upcoming WeatherDuino Pro2 PLUS software v2.xx, which is already on final Beta testing stage.
The large majority of the improvements introduced in v2.xx software series, are not only in the aesthetics aspect of the screens, much by the contrary... With the new v2.xx software, the Davis Vantage Pro2 emulation was largely improved, making the WeatherDuino Pro2 Plus now able to deal with the most significant Davis LOOP2 commands.
As much as I knows, this is the first Davis Vantage Pro2 emulation able to do this.
As always, there isn't any roadmap for the v2.xx launching, however it should happen latter March or start of April.
It all depends on how beta testing phase will run.
Thanks to all Testers/Developers that are helping on this.
Users browsing this thread: 10 Guest(s)
