2.8" tft displays
(15-05-2015, 22:42)Brett Wrote:  The Bon.Display version on ebay does not have a touch panel or controller attached...
It's always good to know some other sources for the displays, but I bought mine from Bon.Display and it have touch panel.
http://www.ebay.com/itm/2-8-240x320-Seri...1c4c9ef8f8
And so it is. Wow, I never thought eBay would be so hard to find LCDs ! AU's ebay searching won't show 2.8" displays, and bon.display's store didn't seem to have touch devices when I ordered. Always good to have options - who doesn't need another display or three Smile
hi guys
I found another source, I bought my LCds here http://www.ebay.com/itm/191531963190
Hoping this is compatible?
http://www.aliexpress.com/item/3-2-TFT-L...80146.html
or
http://www.aliexpress.com/item/3-5-TFT-L...05734.html
I'm pretty sure that the first one isn't as it uses a 16 bit parallel interface rather than a SPI interface. The second one may work but you would have to work out which pins on a Raspberry Pi are used.
Chaos Manor Weather
Mount Evelyn, Australia
http://www.sdsnet.net/weather/cumulus/indexframe.htm
LaCrosse WS-2300, until I have a Weatherduino Pro2 running.
(24-05-2015, 12:08)Stuarts Wrote:  I'm pretty sure that the first one isn't as it uses a 16 bit parallel interface rather than a SPI interface. The second one may work but you would have to work out which pins on a Raspberry Pi are used.
If you scroll down to interface it has pin-outs
It might be compatible, but it also might not be. The SPI interface could be significantly different to the one on all the smaller/previous displays. But if you wanted to give it a try, and report back, that'd be awesome Wink
(25-05-2015, 12:11)Brett Wrote:  It might be compatible, but it also might not be. The SPI interface could be significantly different to the one on all the smaller/previous displays. But if you wanted to give it a try, and report back, that'd be awesome Wink
I ended up going with 2.8" as per OP.
Big Grin
(24-05-2015, 12:04)strada916 Wrote:  Hoping this is compatible?
or
None of them is compatible.
The second one, despite it is SPI, the seller don't even say any info about the chipset driver.
3.2" TFT; will this work?
http://www.ebay.co.uk/itm/400916125089
