WeatherDuino_P2AT328_RX_v4.0_b001 Compile error
Hope someone can help with a compile error I am getting please?
I am using a freshly installed copy of Arduino V 1.8.8, all libraries from the Rar archive have been copied to the Arduino library folder, the file will compile ok, until I change the line below in Config_options  to 1
//   Define Software Operation Mode
#define Work_Mode         1   // Mode 0= Davis VP2 Emulation Mode, Mode 1= EasyWeather Mode
The error relates to the DataFlash library.
Some of the error messages below.
C:\Users\lotus\Documents\Arduino\WeatherDuino_Pro2\v4.0\software\Receiver Software\WeatherDuino_P2AT328_RX_v4.0_b001\Routines.ino: In function 'int Ext_eepromReadInt(int)':
Routines:248:46: error: 'ExternalEeprom_read' was not declared in this scope
   value = value | ExternalEeprom_read(address) << 8;
C:\Users\lotus\Documents\Arduino\WeatherDuino_Pro2\v4.0\software\Receiver Software\WeatherDuino_P2AT328_RX_v4.0_b001\Routines.ino: In function 'void Ext_eepromWriteInt(int, int)':
Routines:255:53: error: 'ExternalEeprom_write' was not declared in this scope
   ExternalEeprom_write(address, (value >> 8) & 0xFF );
Using library DataFlash in folder: C:\Users\lotus\Documents\Arduino\libraries\DataFlash (legacy)
exit status 1
Thanks Andy
Hello Andy,
// -------------------------------------------------------------------------------------- // Define Software Operation Mode // -------------------------------------------------------------------------------------- #define Work_Mode 1 // Mode 0= Davis VP2 Emulation Mode, Mode 1= EasyWeather Mode
Do you really want to run the receiver in EasyWeather Mode rather than Davis VP2 Emulation?
Indeed there is a compilation error when EasyWeather Mode is selected, but the fix is easy. If you really want to run the receiver in EasyWeather mode I can post the fix.
(18-02-2019, 02:32)Werk_AG Wrote:  Hello Andy,
Yes please, if there is any easy fix I would be grateful if you could post it..
Many thanks..
Routines.ino
Find and replace this:
// -------------------------------------------------------------------------------------- // Read / Write a Int to External Eeprom // -------------------------------------------------------------------------------------- int Ext_eepromReadInt(int address) { int value = 0x0000; value = value | ExternalEeprom_read(address) << 8; value = value | ExternalEeprom_read(address + 1); return value; } void Ext_eepromWriteInt(int address, int value) { ExternalEeprom_write(address, (value >> 8) & 0xFF ); ExternalEeprom_write(address + 1, value & 0xFF); }
with this:
// -------------------------------------------------------------------------------------- // Read / Write a Int to External Eeprom // -------------------------------------------------------------------------------------- #if Work_Mode == 0 int Ext_eepromReadInt(int address) { int value = 0x0000; value = value | ExternalEeprom_read(address) << 8; value = value | ExternalEeprom_read(address + 1); return value; } void Ext_eepromWriteInt(int address, int value) { ExternalEeprom_write(address, (value >> 8) & 0xFF ); ExternalEeprom_write(address + 1, value & 0xFF); } #endif
(21-02-2019, 02:34)Werk_AG Wrote:  Routines.ino
with this:
That's perfect, works fine now.
many thanks Andy
