4Pro TX Parts - Printable Version
+---- Thread: 4Pro TX Parts (/thread-2357.html)
4Pro TX Parts - HeavyWeather - 03-03-2025
WeatherDuino 4Pro TX Board Parts
Hello everybody!
I have done a little work to help those struggling to find parts to complete your transmitter boards. I have created a list on DigiKey for everyone to access, but for the moment it is only a parts list for the specified countries/setups. If you would like a parts list for 433 MHz, a different country, or specific specifications of your TX board, PM me and I will absolutely be willing to create more lists for you!
Be warned though. I made this list a week ago and had to use some substitutes for obsolete and out-of-stock parts, but they should still work the same. You can also PM me for any questions, issues, or tips on ways I can improve the lists for you all.
These lists are not just lists but links to DigiKey where you can order the exact amount of parts you will need for a board. The list contains parts that you may or may not need, depending on your choice of setup, so feel free to ask me about it.
I will edit this post and update this thread as I add, edit, or update the lists.
US & AU 915 MHz LoRa Parts Link:
Updated March 3, 2025.
https://www.digikey.com/en/mylists/list/MDHR29ENAA
EU 868 MHz LoRa Parts Link:
Note:
This part list does NOT include the 868 MHz LoRa module, as it is out of stock and special order through DigiKey. Eventually, I can post a second link to the LoRa module separately.
Updated March 4, 2025.
https://www.digikey.com/en/mylists/list/Z5OPUTSMVV
US & AU 315 MHz OOK Parts Link:
WIP
EU 433 MHz OOK Parts List:
WIP
RE: 4Pro TX Parts - PapaErde - 30-10-2025
Thank you @heavyweather for your help regarding the parts. i used the EU LoRa list and ordered at Digikey. First the parcel was lost at austrian customs, then everything went fine, but one part seems wrong:
IC 5 should be AD822 and in your list it´s a TS922IDT. So, did i miss something? Is the TS922 a comparison typ?
Second question regarding the parts: I´m desperatly searching for the parts of the I2C bus extender pcb and cannot find the parts. I even looked in the schematics... So please could anybody give me a little help  Huh
Tnx again and greets from Austria,
PapaErde
RE: 4Pro TX Parts - werk_ag - 31-10-2025
Hi PapaErde
As stated on the official parts list, the reference for the I2C bus extender chip is P82B715.
You can find the specs here: https://www.ti.com/lit/ds/symlink/p82b715.pdf
Regarding the AD822 chip, I don't know if the TS922 is a direct replacement chip.
Rgs,
RE: 4Pro TX Parts - PapaErde - 31-10-2025
Thanks for the help werk_ag.  I´ve recognised the 82B715 as TX chips on the main TX board. But i was searching for the part list of the extender pcbs and found it here https://www.meteocercal.info/forum/thread-1898.html
Maybe the TS922 was mistakenly added by heavyweather on his digikey-list. So again: Thanks for the service and maybe he´ll check the shopping list.
Greetings from Austria
