NOAA/METEOR satellite -
meteoestarreja - 02-02-2015
Hi everybody,
I managed to fix my weather satellite receiver this weekend but I realized that I must improve my antenna too.
From what I saw, I believe that QHF antenna is the one that I should do right now (before I used a turnstyle antenna) but there is so many choices regarding to the materials ... anyone does have any experience in such materials? (copper, aluminium, brass, etc)
Best regards
RE: NOAA/METEOR satellite -
moolight0551 - 10-04-2015
(02-02-2015, 12:02)meteoestarreja Wrote: anyone does have any experience in such materials? (copper, aluminium, brass, etc)
Best regards
Hi, I looked into building a QFH some time ago and found a few articles on the web. Most seem to use copper water pipe, used in the airconditioning industry. I also saw one using coax cable which I started building but like most projects never finished.
I use a ground plane style antenna made out of aluminium rod with a LNA but I don't have a very good site and can only see in one direction which limits reception somewhat.
Here are a few links
http://www.alternet.us.com/?p=1461
http://www.g4ilo.com/qfh.html
http://www.wxtoimg.com/hardware/
meteoestarreja - 15-04-2015
(10-04-2015, 01:12)moolight0551 Wrote: Most seem to use copper water pipe, used in the airconditioning industry. I also saw one using coax cable which I started building but like most projects never finished.
Thanks for the info sharing.
My doubts was about the materials. I also saw a project using coaxial cable but I don't know why, I didn't like the looks of it
I'll try to get some copper pipe and try it.
Also remembered to do it with aluminium pipe ... let's see witch way to follow when I have some free time.
If I may ask, witch LNA are you using?
moolight0551 - 16-04-2015
Quote:If I may ask, witch LNA are you using?
I'll need to get back to you on the LNA. The details are on my main computer which has decided to go faulty so when I get it up and running again, I'll send you the details.
meteoestarreja - 16-04-2015
(16-04-2015, 02:00)moolight0551 Wrote: I'll need to get back to you on the LNA. The details are on my main computer which has decided to go faulty so when I get it up and running again, I'll send you the details.
moolight0551 - 20-04-2015
(16-04-2015, 08:58)meteoestarreja Wrote: (16-04-2015, 02:00)moolight0551 Wrote: I'll need to get back to you on the LNA. The details are on my main computer which has decided to go faulty so when I get it up and running again, I'll send you the details.
Found it. It is a LNA for All. Have a look at this site. I ordered one and the guy who sent it would not accept payment until I let him know I received it. I had to put it in a box(diecast) with coax connectors IN/OUT.
http://lna4all.blogspot.ie/
meteoestarreja - 20-04-2015
(20-04-2015, 04:16)moolight0551 Wrote: Found it. It is a LNA for All. Have a look at this site. I ordered one and the guy who sent it would not accept payment until I let him know I received it. I had to put it in a box(diecast) with coax connectors IN/OUT.
Nice
Thanks for the info, probably I will contact Adam 9A4QV - an amateur radio operator like me, and buy one too
