error compilation with LCD 20x4 - Printable Version
+--- Thread: error compilation with LCD 20x4 (/thread-1324.html)
error compilation with LCD 20x4 - f4aii - 26-01-2018
hello,
following 2 compilation errors for use with a 20X4 LCD on the RX PRO2 + V500_b002 with IDE 1.8.5 on MAC, I modified the code in the D_LCD tab
line 114: else if (UV_OutUnit! = 9 TX_Unit [UV_OutUnit] .UV! = 0) L_info = 5;
i wrote:   else if (UV_OutUnit! = 9 && TX_Unit [UV_OutUnit] .UV! = 0) L_info = 5;
[Image: captur10.png]
now, it's OK
RE: error compilation with LCD 20x4 - werk_ag - 27-01-2018
(26-01-2018, 23:07)f4aii Wrote:  following 2 compilation errors for use with a 20X4 LCD on the RX PRO2 + V500_b002...
I think you mean RX Pro2 PLUS + V500_b002
Thank you, indeed the error exists, and your solution is correct.
Somehow during some edition I deleted the && and haven't noticed it... the LCD rarely is used with te Pro2 PLUS.
RE: error compilation with LCD 20x4 - f4aii - 27-01-2018
I am preparing a weather station that will be in an uninhabited cabin at 2000m altitude and the TFT screen will be really useless.
As there is a wifi beam on the 10 km that separate us, a set TX, RX, UV, AQI will take place. As there is a lot of frost on this site, I will not put a cup anemometer, I will see later the design of an ultrasound model.
Here is why I use a LCD 20X4 which indeed must be very rare.
I wrote the wrong version of my platinum, it is a RX PRO2 PLUS V1.3, soft V500_b002.
RE: error compilation with LCD 20x4 - f4aii - 30-01-2018
same file, same hardware, i have an error on line 124:
#if (SR_OutUnit != 9)    case 4:      {        lcd.setCursor(0, 3);        lcd.print(F("Solar Rad: "));        lcd.print(TX_Unit[SRUV_OutUnit].SolarRad);        lcd.print(F(" Wm2"));        if (UV_OutUnit != 9 && TX_Unit[UV_OutUnit].UV != 0) L_info = 5;        else L_info = 1;        break;      }
i change for:
#if (SR_OutUnit != 9)    case 4:      {        lcd.setCursor(0, 3);        lcd.print(F("Solar Rad: "));        lcd.print(TX_Unit[[b]SR[/b]_OutUnit].SolarRad);        lcd.print(F(" Wm2"));        if (UV_OutUnit != 9 && TX_Unit[UV_OutUnit].UV != 0) L_info = 5;        else L_info = 1;        break;      }
It's OK for use with BMP280 and SHT31
But i have these errors if i select BME280 for pressure and int temp. Error on line 404: BME280 bme;
// -------------------------------------------------------------------------------------- //  WeatherDuino Pro2 PLUS RF Receiver - Version: 5.0 b002 //          Start of user configurable options // -------------------------------------------------------------------------------------- // If you need help about any of the user configurable settings, please first do a search // at the WeatherDuino Pro2 support forum. If you don't find any relevant info, then post // a new thread. // // -------------------------------------------------------------------------------------- //   Define Name and ID's for this weather station // -------------------------------------------------------------------------------------- const String WeatherStation_Name = "Susville 3 test"; // This is important, put here your Weather Station name (don't use special chars, like accents) #define Station_ID      0xA1    // Station_ID, use the same value in all TX units #define Relay_ID        0xEE    // Relay_ID,   use the same value in all WD units // -------------------------------------------------------------------------------------- //   Define your Weather Station location. Use decimal format for Latitude and Longitude // -------------------------------------------------------------------------------------- #define LATITUDE      44.926    // Put here your Station latitude in degrees North (always use 3 decimal places) #define LONGITUDE     5.777    // Put here your Station longitude in degrees - minus for West (always use 3 decimal places) #define ELEVATION     900       // Put here your Station height above sea level in Meters (no decimal places) // -------------------------------------------------------------------------------------- //   Define rules for Auto Summer Time Display, and clock adjustment // -------------------------------------------------------------------------------------- #include <Timezone.h> // Example for Australia Eastern Time Zone (Sydney, Melbourne) // TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours // TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours // Timezone myTZ(aEDT, aEST); TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 120};   //Portuguese Summer Time -  "UTC + 1" or GMT + 1 TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 60};    //Portuguese Winter Time -  "UTC + 0" or GMT Timezone myTZ(PST, GMT); // -------------------------------------------------------------------------------------- //   Define Interface Language // --------------------------------------------------------------------------------------       #include "_lang/fr_FR.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end                              // Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL // -------------------------------------------------------------------------------------- //   Define Roll Over Hour for Meteorological Day // -------------------------------------------------------------------------------------- #define MeteoDay_HStart 0    // Use values from 0 to 23 // -------------------------------------------------------------------------------------- //   Define Display Backlight TimeOut // -------------------------------------------------------------------------------------- const byte  BackLight_Timeout = 0;   // Timeout for display backlight in minutes (1 to 255). 0 = Always ON #define Use_BigClock             0    // Instead of turn off TFT backlight show a big clock screen. 0= No, 1= Yes // -------------------------------------------------------------------------------------- //   Define data display units // -------------------------------------------------------------------------------------- #define Date_Time_Format  0    // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd #define Temp_Display_Unit 0    // 0 for ºC, 1 for ºF #define ATM_Display_Unit  0    // 0 for mBar, 1 for inHg #define Rain_Display_Unit 0    // 0 for mm, 1 for inches #define Wind_Display_Unit 0    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots // -------------------------------------------------------------------------------------- //   Define the type of your Barometric Pressure Sensor // -------------------------------------------------------------------------------------- #define Barometric_Sensor  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180 // -------------------------------------------------------------------------------------- //   Define the type of your inside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define InsideTH_Sensor   0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31 // -------------------------------------------------------------------------------------- //   Fine adjusts for Inside Temperature and Barometer // -------------------------------------------------------------------------------------- const int   TemperaturaInt_offset =   -13;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC) const float pressure_offset       =   0;   // Pressure Fine Adjust in mB // -------------------------------------------------------------------------------------- //   Define the type of your outside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define MainOutTH_Sensor 0   // 0 for sensor type SHT31, SHT21 or HTU21D, 1 for sensor type SHT1x or DHT22 // -------------------------------------------------------------------------------------- //   Define Wind Speed and Wind Gust resolution // -------------------------------------------------------------------------------------- // This setting only have effect when the software is used in Davis VP emulation mode #define VP2_WindRes     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h                             // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h                             // WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,                             // but also limits both of them, to a maximum reading of just 91.8 Km/h                             // If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).                             // Weather Display users should set this option to 0 - Standard Davis wind resolution   // -------------------------------------------------------------------------------------- //   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers) // -------------------------------------------------------------------------------------- #define WindSpikeControl 1   // 0= Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define the source of your main outside sensors // -------------------------------------------------------------------------------------- // ---- If you are using just one TX board, the source for all items should be equal to your single TX Unit ID (most likely zero). // ---- Define the source of your main Temperature / Humidity sensor #define TH_OutUnit       0   // 0= Temp/Hum sensor connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Temp / Hum // ---- Define the source of your Main Wind sensor #define WIND_OutUnit     0   // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Wind Speed & Dir // ---- Define the source of your main Rain Gauge #define RAIN_OutUnit     0   // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Rain Gauge // ---- Define the source of your main Solar Radiation sensor #define SR_OutUnit       0   // 0= Solar Radiation sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // ---- Define the source of your main UV sensor #define UV_OutUnit       0  // 0= UV sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // -------------------------------------------------------------------------------------- //   Define the type of your Solar Radiation device // -------------------------------------------------------------------------------------- #define Solar_Sensor     1   // 1= Solar Cell "Pyranometer", 2= Apogee SP-110 Pyranometer, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor                             // ---- Support for sensor type 4 is experimental (type 4 is a PAR sensor) // -------------------------------------------------------------------------------------- //   Define the type of your UV device // -------------------------------------------------------------------------------------- #define UV_Sensor        1   // 1= UVM-30A, 2= VEML6075, 3= Reserved #define UV_Transmission 65   // UV Transmission percentage of UV sensor cover material. // -------------------------------------------------------------------------------------- //   Extra Sensors Settings and Mapping // -------------------------------------------------------------------------------------- // ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used. //      Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1 // // ---- Source 0 means TX unit0, 1 means TX unit1... // ---- Source 6 (Reserved) // ---- Source 7 is for BIOS Sensor (Only Temperature is shown) // ---- Source 8 is for Air Quality Monitor. 0= Temperature/Humidity, 1= Dust Density/AQI // ---- (AQI sensors can be mapped to any position, but should be mapped in sequence, Temperature/Humidity always first) // // ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units) // ---- Example: // ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6     //#define ExtraSensors_Source { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{8,1} } //               {0,0} - First extra sensor (ES0), will be sensor 0 from TX unit0 //               {0,1} - Second extra sensor (ES1), will be sensor 1 from TX unit0 //               {1,0} - Third extra sensor (ES2), will be sensor 0 from TX unit1 //               {9,9} - Fourth extra sensor (ES3), not used - not mapped //               {9,9} - Fifth extra sensor (ES4), not use - not mapped //               {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor //               {8,1} - Seventh extra sensor (ES6), will be Dust Density / AQI index from the Air Quality Monitor // //-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6     #define ExtraSensors_Source { {0,0},{0,1},{9,9},{9,9},{9,9},{8,0},{8,1} } // ---- Define personalized names for each Extra sensor. Attention, 8 chars maximum // ---- There is no need to define a name for the Extra Sensor mapped to the Dust Density / AQI index data //                   Max. Size  [--------] const char ESname_1[] PROGMEM = "dehors";           // 8 chars max const char ESname_2[] PROGMEM = "boitier";           // 8 chars max const char ESname_3[] PROGMEM = "-";           // 8 chars max const char ESname_4[] PROGMEM = "-";           // 8 chars max const char ESname_5[] PROGMEM = "-";           // 8 chars max const char ESname_6[] PROGMEM = "AQM";     // 8 chars max const char ESname_7[] PROGMEM = "AQM";           // 8 chars max // -------------------------------------------------------------------------------------- //   BIOS soil moisture sensor settings // -------------------------------------------------------------------------------------- // ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID #define BiosSensor_ID 0   // Device ID in HEX format, or 0 not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Settings and Sensors Mapping //   (The mapping logic is the same than used with the Extra Sensors) // -------------------------------------------------------------------------------------- // 0 = Soil Leaf Interface not used // 1 = Soil Leaf Interface connected to a TX unit #define SoilLeaf_Interface  0   // 0, 1, // ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source // ---- For BIOS Soil Temp / Moisture use 7 as source // ---- To disable use 9 in both fields //                                 S1    S2    S3    S4 #define SoilTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} } #define LeafTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} } #define SoilMoistSensors_Source { {9,9},{9,9},{9,9},{9,9} } #define LeafWetSensors_Source   { {9,9},{9,9},{9,9},{9,9} } // ---- Define personalized names for each Soil and Leaf sensor. Attention, 8 chars maximum //              Soil Max. Size  [--------] const char SSname_1[] PROGMEM = "-";            // 8 chars max const char SSname_2[] PROGMEM = "-";            // 8 chars max const char SSname_3[] PROGMEM = "-";            // 8 chars max const char SSname_4[] PROGMEM = "-";            // 8 chars max //              Leaf Max. Size  [--------] const char LSname_1[] PROGMEM = "1";            // 8 chars max const char LSname_2[] PROGMEM = "2";            // 8 chars max const char LSname_3[] PROGMEM = "3";            // 8 chars max const char LSname_4[] PROGMEM = "4";            // 8 chars max // Define VWC calculation method // Method 1 applies only for VH400 soil moisture sensor // // METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer // at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml // // METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) . #define VWC_CalcMethod 1 // Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface // Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry) //                                                  ADC1  ADC2  ADC3  ADC4   const uint16_t AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts const uint16_t AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 }; // -------------------------------------------------------------------------------------- //   Broadacasting settings for Wireless Display Units // -------------------------------------------------------------------------------------- #define Relay_Data       1   // 0= Disables Data Relay, 1= Enables Data Relay // -------------------------------------------------------------------------------------- //   Davis compatible Data Logger Settings // -------------------------------------------------------------------------------------- #define Logger_Enable    1   // 0= Disable 1= Enable byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30) // -------------------------------------------------------------------------------------- //   Define type of your Weather Software // -------------------------------------------------------------------------------------- #define WeatherSoft      0   // 0= CumulusMX, 1= Any other (Cumulus 1, WeewX, Weather Display, etc.) // -------------------------------------------------------------------------------------- //   Easyweather format data Output // -------------------------------------------------------------------------------------- #define Easyweather_Out  0   // 0= Disable (defaut) 1= Enable // -------------------------------------------------------------------------------------- //   Internet Settings // -------------------------------------------------------------------------------------- #define Enable_Internet     1                       // 1= Enable Internet connection, 0= Disable // ---- NTP Settings ---- #define Enable_NTP          1                       // 1= Enable Sync time with NTP servers, 0= Disable // NTP Servers: #define timeServer "pool.ntp.org" //#define timeServer "time.nist.gov"                 // ntp1.nl.net NTP server //#define timeServer "80.96.196.58"                  // timp.mcsi.ro //#define timeServer "193.79.237.14"                 // ntp1.nl.net NTP server // ---- Weather Wunderground Settings ---- #define Enable_WUupload     1                       // 1= Enable upload to Wunderground, 0= Disable #define WUupload_period     3                        // Period in minutes between uploads to WU (Should be >= 3 minutes, if less defaults to 4 minutes) #define WUupload_InTemp     1                        // 1= Enable upload of Inside Temperature / Humidity, 0= Disable // ---- Air Quality Monitor - Upload to ThingSpeak Settings ---- #define Enable_AQMtoThingSpeak   1                   // 1= Enable, 0= Disable // ---- Web Server Settings ---- #define Enable_WebServer          1                  // 1= Enable 0= Disable #define WebServer_port           80                  // WebServer port (default 80) // -------------------------------------------------------------------------------------- //   Enable / Disable GPIO routines - General Purpose Input / Output ports // -------------------------------------------------------------------------------------- #define UseGPIO  0   // 0=Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define display order of data screens on the TFT //   Use sequentially numbers from 1 to 4. Use 9 to prevent a particular data screen to be shown // -------------------------------------------------------------------------------------- #define ExtraSensors_Data 3 #define SoilLeaf_Data     4 #define AirQuality_Data   1 #define TXinfo_Data       2 // -------------------------------------------------------------------------------------- //   Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- #define TestMode    false    // false= Normal working mode, true= Test mode only (no logger, no usb connection) /*************************************************************************************     Hardware Settings *************************************************************************************/ // -------------------------------------------------------------------------------------- //   Define PCB Version Number // -------------------------------------------------------------------------------------- //                              Take particular attention to this setting. //                              Your system may not work properly if you define a wrong pcb version number. //                              In case of doubt check what is printed in your pcb. #define Board_Version   13   // PCB version number, without the decimal point Ex: 1.3 = 13 (integer number) // -------------------------------------------------------------------------------------- //   Define your Display type // -------------------------------------------------------------------------------------- #define DisplayType     1    // 1= LCD 20x4, 3= TFT 320x240 ILI9341 // -------------------------------------------------------------------------------------- //   Define LCD I2C address // -------------------------------------------------------------------------------------- // Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display // Default address will work most of the times! #define LCD_I2C_Address     0x39   // -------------------------------------------------------------------------------------- //   SHT31 I2C Address - Default address will work most of the times! // -------------------------------------------------------------------------------------- #define SHT31_address       0x44       // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Presure Sensor Address (no need to change) // -------------------------------------------------------------------------------------- //#define BMP085_ADDRESS    0x77       // I2C address of BMP085 or BMP180 // -------------------------------------------------------------------------------------- //   Debug helper // -------------------------------------------------------------------------------------- //#define PRINT_DEBUG_NTP_UPDATE    // Print to serial monitor messages related to sync time with NTP server //#define PRINT_DEBUG_WU_UPLOAD     // Print to serial monitor messages related to Weather Underground upload. //#define PRINT_DEBUG_TS_UPLOAD //#define PRINT_DEBUG_VCHECK //#define PRINT_DEBUG_TCP_SERVER //#define PRINT_DEBUG_AURIOL //#define PRINT_DEBUG_BIOS // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
Arduino : 1.8.5 (Windows 7), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
WeatherDuinoPro2Plus_RX_v500_b002:404: error: cannot declare variable 'bme' to be of abstract type 'BME280'
BME280 bme;
In file included from C:\Users\jch\Desktop\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002\WeatherDuinoPro2Plus_RX_v500_b002.ino:53:0:
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:52:7: note:   because the following virtual functions are pure within 'BME280':
class BME280{
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:66:16: note: virtual void BME280::WriteRegister(uint8_t, uint8_t)
  virtual void WriteRegister(uint8_t addr, uint8_t data)=0;
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:69:16: note: virtual bool BME280::ReadTrim()
  virtual bool ReadTrim()=0;
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:72:16: note: virtual bool BME280::ReadData(int32_t*)
 virtual bool ReadData(int32_t data[8])=0;
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:89:16: note: virtual bool BME280::begin()
  virtual bool begin()=0;
C:\Users\jch\Desktop\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002\Routines.ino: In function 'void read_InsideTH_Sensor()':
Routines:330: error: no matching function for call to 'BME280::ReadData(float&, float&, float&, bool, bool)'
  bme.ReadData(pres, temp, humd, true, true);     // Parameters: (float& pressure, float& temp, float& humidity, bool hPa = true, bool celsius = false)
C:\Users\jch\Desktop\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b002\Routines.ino:330:44: note: candidate is:
C:\Users\jch\Documents\Arduino\libraries\libraries\BME280\src/BME280.h:72:16: note:   candidate expects 1 argument, 5 provided
exit status 1
RE: error compilation with LCD 20x4 - werk_ag - 31-01-2018
This is from the download page:
IMPORTANT:
Compile with Arduino IDE 1.8.3 or newer
Always compile using only the provided libraries.
From the error messages I see that you are using an BME library which isn't compatible. Try using the BME library suplied with the software package, and the code will compile fine (I'm using a BME280 myself).
RE: error compilation with LCD 20x4 - f4aii - 01-02-2018
I made the mistake of using my desktop PC that contains other libraries in addition to weatherduino. IDE chooses the wrong library.
I still have the error message for line 124 in the D_LCD tab,
must be fixed:
lcd.print(TX_Unit [SRUV_OutUnit] .SolarRad);
and put:
lcd.print (TX_Unit [UV_OutUnit] .SolarRad);
I have no other errors now.
Too bad the error messages are so little understandable for beginners like me.
Thanks for your help.
RE: error compilation with LCD 20x4 - werk_ag - 02-02-2018
Thank you for spotting this to me. It will be fixed on next software release.
However please note that the fix for line 124 should be:
lcd.print(TX_Unit[SR_OutUnit].SolarRad);
and not
which only works when the source for Solar Radiation data is the same than UV data (which happens in most of the cases).
RE: error compilation with LCD 20x4 - f4aii - 03-02-2018
I do not understand much about codes, I modified by deduction.
Right now, I am changing the code for my brother who is color-blind, he only sees white, gray, black and yellow. I change the color of the dots around the clock so that he can tell me if the weatherduino is connected or not. Nothing complicated to do.
thank you
RE: error compilation with LCD 20x4 - werk_ag - 04-02-2018
(03-02-2018, 09:30)f4aii Wrote:  I do not understand much about codes, I modified by deduction.
However, you already have helped me to find some bugs... Smile
(03-02-2018, 09:30)f4aii Wrote:  Right now, I am changing the code for my brother who is color-blind, he only sees white, gray, black and yellow. I change the color of the dots around the clock so that he can tell me if the weatherduino is connected or not. Nothing complicated to do.
thank you
If I could help with anything on this matter, please let me know, I will be glad to help to make the system usable for your brother.
