Temperature value freezes - Auriol Weather Station - Printable Version
+--- Thread: Temperature value freezes - Auriol Weather Station (/thread-1757.html)
Pages: 1 2 3 4 5
RE: Temperature value freezes - werk_ag - 20-01-2020
Hi Marco,
Please download and install latest Pro2 Compact software, released today (WeatherDuino Pro2 Compact - RX v3.1_b012).
It should fix definitively the temperature freezes and spikes with the Auriol weather stations and compatibles.
Regarding the strange rainfall figures at WU, can you please confirm that you performed a "Factory Reset" of the receiver?
Pressing the D1 mini reset button, doesn't perform the "Factory Reset" task. You should do it through the option available on the Menu, see image below: Last option at bottom right.
[Image: pro2_compact_menu_web640.jpg]
Look forward to hearing from you
RE: Temperature value freezes - bigcake - 20-01-2020
(20-01-2020, 01:23)Werk_AG Wrote:  Hi Marco,
Hi Caniera
I try to install the new version of Firmware that you released today (but the red LED on the WeatherDuino Compact monitor should not turn on?) And I will check in the next days if there are no more problems.
I performed the factory reset with the menu button, I loaded the firmware again and I subsequently reset the D1 and as you can see from the graph, the "Prec. Rate" value went to a high value for 50 minutes
(19-01-2020, 22:57)engolling Wrote:  @bigcake, can you estimate how often do you receive corrupted auriol wireless data displayed on your Weatherduino?
Regards, Engolling
Hi Engollling,
after updating the firmware with the Wireless_sensor v2 module there was a first moment, about 15 minutes, in which it happened to me at least three / four times. The reading of corrupt data on the display lasted 20/30 seconds and then returned to real values.
I was unable to check the display afterwards, but yesterday and today WU had no abnormal peaks
(20-01-2020, 21:26)bigcake Wrote:  ...
Once you will be running latest software (Wireless_Sensors v2 has bugs, so update is really needed), I hope you will be able to confirm us that corrupted Temp / Hum data isn't happen any more.
Is this your WU page? https://www.wunderground.com/dashboard/pws/ISPINE2
RE: Temperature value freezes - xxDvDxx - 20-01-2020
Hope soon you will be able to confirm us that the corrupted Temp / Hum data isn't happen any more.
Hi everyone,
i was not home and I still not home in these days so I couldn’t do test , but I can see what WU read from the Pro2C .. in my case the temperature freeze only when it reach values lower than zero , usually bellow 0.2 degrees . I didn’t changed yet the wireless v2 file so just keep it as my case only, but I never had any problems with everything else ( pressure and rain ) .
I see there is a new sw version so I will download it soonest to give more feedback to everyone.
Hi everyone,
Hi xxDvDxx,
Upgrade when you can, then please report back. I'm quite confident that those issues are finally solved.
Thank you
RE: Temperature value freezes - bigcake - 21-01-2020
Regards, Engolling
Hi Engollling, now I have seen the display with a negative temperature peak (-115 ° C unreal) and it lasted about 105 seconds before returning to the normal temperature level (1.4 ° C).  I have not yet upgraded to the new firmware version
Hi Caniera, yes this is my WU page.
Recognizing your experience with Arduino, what is the best procedure to upgrade without losing the settings in the files?
Marco
RE: Temperature value freezes - xxDvDxx - 21-01-2020
Hi everyone,
RE: Temperature value freezes - engolling - 21-01-2020
I think that Werks new software update will solve the freezes. You can just update our config and credentials in the new software and then everything should go on without problems.
