WeeWx extra data plugin - Printable Version
+--- Forum: Third-party Addons (https://www.meteocercal.info/forum/forum-51.html)
+--- Thread: WeeWx extra data plugin (/thread-1591.html)
RE: WeeWx extra data plugin - engolling - 31-01-2019
Changed the attachment in the first post.
Changelog:
- updated to version 05
- better unit handling.
- addon should work with all database unit types now (not tested yet)
- installation manual updated to version 1.2
There are still some strange things going on with WeeWx because temperatures somehow have to be converted to degree Fahrenheit (default US unit) even if the database is metric, but other signals like snow height are working fine without conversion. I will check this topic the next days but up to now everything seems to work.
RE: WeeWx extra data plugin - werk_ag - 31-01-2019
(31-01-2019, 22:36)engolling Wrote:  There are still some strange things going on with WeeWx because temperatures somehow have to be converted to degree Fahrenheit (default US unit) even if the database is metric, but other signals like snow height are working fine without conversion. I will check this topic the next days but up to now everything seems to work.
Don't know if this info is important for the plugin, but since Weewx is expecting data from a Davis weather station, it also expects that all temperature data arrive in ºF.
RE: WeeWx extra data plugin - engolling - 03-02-2019
Hi Werk,
I figured that already out, it was only a bit strange that it seemed that only temperature is needed in USUnits and nothing else. But this was a mistake.
All values given to WeeWx have to be in USUnits to work correctly. If the conversion factor is 1 it makes of course no difference.
Everything should work fine for now - there will be an update of the manual soon.
Regards, engolling
RE: WeeWx extra data plugin - engolling - 18-02-2019
Changelog:
- moved everything to GitHub. Changements can be reviewed via GitHub
- Bigger changes will also be mentioned here
- Fixed unit bug
RE: WeeWx extra data plugin - engolling - 05-03-2019
Changed source at GitHub
Changelog:
- working on integration of more rain gauges that are not supported on the davis protocol, for example a RG11
At the moment I have some troubles getting the data correctly to WeeWx probably because of timing issues.
I have asked for support in the WeeWx group - I will see what will happen and how to find a solution Wink
https://groups.google.com/forum/#!topic/weewx-user/jq9AcxTzKr0
Best regards,
RE: WeeWx extra data plugin - engolling - 15-07-2019
Changelog:
- multiple rain gauges (from different TX) can be imported if you change the source code of the WeahterDuino
- Unit handling before importing it to WeeWx database finalized - everything should work now under each condition
Apart from some cosmetic changes the plugin should now be fully functional  Music
RE: WeeWx extra data plugin - engolling - 10-10-2019
Updated on GitHub.
Changelog:
Corrected handling of None values to prevent errors.
RE: WeeWx extra data plugin - engolling - 01-01-2021
Updated the git source.
Plugin is now compatibel with WeeWX running on Python 3.
