RE: Raspberry Pi and Cumulus MX - "How To Guide" -
f4aii - 26-02-2018
I encountered a cumulus reading problem, the error messages were more or less random but in the form 0x10, 0x12, 0x14 ....
I made a loop in a ferrite ring with the USB cable and since I have more errors.
A short and shielded (thick) USB cable should also be used.
I can provide you with an ISO image for raspberry as needed.
werk_ag - 26-02-2018
I never use any USB cable that isn't shielded, and have a ferrite, this is especially important to connect WeatherDuino to a PC or PI.
markkkk42 - 17-05-2018
Hi All.. great info on these pages as usual. I know what attacks are like now. I have a multimode digital radio repeater that runs a Pi and stm32 processor for the digital radio modes now installed at one of my radio sites. The router is a sim router on wireless broadband. I have been looking at the logs and thankfully this router has a very good firewall and looking at the logs it was literally getting attacked within minutes. So I now realise what can happen. I am just setting up cumulus on a Pi3 now so will not give any access to it. Hopefully I can get it all working with my weatherduino. The V1 setup instructions are a bit out of date but I seem to be getting through it all ok. ±Still have to find out why my weatherduino is not uploading to WU yet. Suggestions on another thread are helping and I am going through them. The wifi seems to be working from the debug but I will post that to make sure
markkkk42 - 20-05-2018
The Pi experts here with CumulusMX...I have a question about making the Pi autoboot at startup or loss of supply so it just boots and starts up CumulusMX. Pretty much like making a autoexec.bat file for startup
hornychz - 20-05-2018
(20-05-2018, 12:44)markkkk42 Wrote: The Pi experts here with CumulusMX...I have a question about making the Pi autoboot at startup or loss of supply so it just boots and starts up CumulusMX. Pretty much like making a autoexec.bat file for startup
I recommend to use very good script from "slashmusic"
http://sandaysoft.com/forum/viewtopic.php?f=27&t=13767
moolight0551 - 28-03-2020
Hi Wizza
Just used your Cumulus MX setup guide and nailed it first time on a RPi3. Thanks.
There are a couple of typos I found that might confuse Linux newbies.
Page 4 near the bottom. sudo apt-get-update should be sudo apt-get update
and sudo apt-get-upgade should be sudo apt-get upgrade
Page 7 near bottom ie Create new folder etc. sudu mkdir CumulusMX should be sudo mkdir CumulusMX
Great job!
Cheers Dave
