Screen_timer var - Printable Version
+--- Forum: Wireless Display for WeatherDuino Weather Stations (https://www.meteocercal.info/forum/forum-60.html)
+---- Forum: User support forum for 4Pro Wireless Display devices (https://www.meteocercal.info/forum/forum-64.html)
+---- Thread: Screen_timer var (/thread-2273.html)
RE: Screen_timer var - hornychz - 19-06-2024
(19-06-2024, 05:03)Sun_Dancer Wrote:
(19-06-2024, 01:55)werk_ag Wrote:  For me to check, can you please specify to which firmware do you refer? Firmware for the older WD unit, or for the newer WD II units?
it's about the WeatherDuino Wireless Display - v7.4_b006 - Release date: 2024-01-07 - Firmware.
I have the same experience with this firmware. I just didn't announce it in January, even though I promised to... Sorry about that.
RE: Screen_timer var - werk_ag - 20-06-2024
(19-06-2024, 05:03)Sun_Dancer Wrote:  Hello Werk_AG,
Greetings, André
Thanks André and hornychz, I will give a look as soon as possible.
RE: Screen_timer var - werk_ag - 07-07-2024
André and hornychz,
Please check latest firmware Wireless Display - v7.4_b007 - Release date: 2024-07-07 and report back.
RE: Screen_timer var - hornychz - 08-07-2024
(07-07-2024, 23:33)werk_ag Wrote:  André and hornychz,
Thank you for now, I will check it...
RE: Screen_timer var - werk_ag - 09-07-2024
Thank you Zdenek,
The problem was caused because in v7.4_b006 I changed to uppercase the name of some vars on the Config_Options.h file, and by mistake I added the old v7.4_b005 Config_Options.h file on the v7.4_b006 firmware package. Happily that only has affected te Screen saver function.
Anyway I will apprecite your feedback (from Sun_Dancer too).
RE: Screen_timer var - hornychz - 11-07-2024
(09-07-2024, 00:19)werk_ag Wrote:  The problem was caused because in v7.4_b006 I changed to uppercase the name of some vars on the Config_Options.h file, and by mistake I added the old v7.4_b005 Config_Options.h file on the v7.4_b006 firmware package. Happily that only has affected te Screen saver function.
Hello, my friend,
Now it is OK, screen saver is functional.  Heart  Good job, thank you.
I am not aware of any other errors.
(It's just that the time synchronization with NTP doesn't start well, but I think my old firewall is a bit angry.
Sometimes it doesn't want to let completely legal packets through - we're both probably too old...  Wink )
RE: Screen_timer var - werk_ag - 18-07-2024
Dear Zdenek,
Thank you for your feedback regarding the Screen Saver function.
I already have noticed that the time synchronization with NTP not always happen right after a startup or reboot, but after one or two minutes time will be correct. I know why this happens but haven't yet found a nice way to fix it.
Kind regards to you and family.
