If you get real stuck you can sent it to me and I'll take a look at it Pete.
Thanks Bob I might end up taking you up on a very generous offer- but i will persevere a little longer for now.
OK. Had a go at this tonight. This is how I configured the debug terms..
Port was com4. Baud rate was set to 9600 and "no line ending" was chosen.
This was the output - which I assume is rubbish. Is there anything i did wrong ?
You have to set the baud rate to 19200...
Thanks for the advice here is the output. Sorry but I dont understand "bring the output inside the code tags". I did notice there is some minor "schmutz" on the RF TX board. I cleaned this up but it does not seem to have made a difference. The TX LED on the nano now flashes regularly, but not the tx led on the tx board. I assume the device should still "work" with the IDE monitor configured "on" ?
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 109.04
WindDir: 245 WindDirName: SW
Min Vane Reading: 0 - Max Vane Reading: 1023
0, 0, 0, 0, 5, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 30.29, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 5.80
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 4.85
0, 0, 0, 0, 10, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 1.35, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 5.04
0, 0, 0, 0, 15, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 1.40, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 3.77
Sending ID0...
Sensor 0 - Temp: 15.40 Hum: 98.15
Sensor 1 - Temp: 0.00 Hum: 0.00
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 2.43
0, 0, 0, 0, 20, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 0.67, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 2.22
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 4.03
0, 0, 0, 0, 25, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.12, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 4.11
0, 0, 0, 0, 30, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.14, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 5.54
Sending ID3...
Collector Type: 0.25
Total Rain: 2555.748
Rain Fall Tips /h: 0
Rain Fall Rate mm/h: 0.00
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 6.30
Sending ID0...
Sensor 0 - Temp: 15.42 Hum: 98.11
0, 0, 0, 0, 35, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.75, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 7.86
WindDir: 249 WindDirName: WSW
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 8.19
WindDir: 250 WindDirName: WSW
0, 0, 0, 0, 40, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.28, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
0, 0, 0, 0, 45, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.61, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 5.90
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 7.67
0, 0, 0, 0, 50, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.13, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID0...
Sensor 0 - Temp: 15.44 Hum: 98.19
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 8.66
0, 0, 0, 0, 55, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.41, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 8.72
WindDir: 253 WindDirName: WSW
Sending ID2...
Wind Speed Km/h (10m Avg): 0.00 WindGust Km/h: 8.12
WindDir: 254 WindDirName: WSW
0, 0, 0, 0, 60, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 1.46, 0, 2.26, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.92
Sending ID3...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.22
WindDir: 255 WindDirName: WSW
0, 0, 0, 0, 65, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 1.46, 0, 2.01, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.44
WindDir: 259 WindDirName: WSW
Sending ID0...
Sensor 0 - Temp: 15.45 Hum: 98.14
0, 0, 0, 0, 70, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.07, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 9.19
WindDir: 262 WindDirName: WSW
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 9.38
WindDir: 264 WindDirName: WSW
0, 0, 0, 0, 75, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.61, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 8.09
Sending ID5...
A2 :684 BatVolt : 13.51
SysTempADC : 1023 SysTempC :59.89
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.83
0, 0, 0, 0, 80, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.62, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 6.51
Sending ID0...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.88
0, 0, 0, 0, 86, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.19, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.87
0, 0, 0, 0, 91, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.19, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.80
WindDir: 265 WindDirName: WSW
Sending ID3...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 6.74
0, 0, 0, 0, 96, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.87, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.77
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.68
0, 0, 0, 0, 101, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.58, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID0...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.62
0, 0, 0, 0, 106, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.56, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 7.03
0, 0, 0, 0, 111, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.95, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 5.45
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 3.75
0, 0, 0, 0, 116, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.04, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID0...
Sensor 0 - Temp: 15.45 Hum: 98.13
Sending ID2...
Wind Speed Km/h (10m Avg): 5.25 WindGust Km/h: 2.71
0, 0, 0, 0, 121, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.75, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 2.58
Sending ID3...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 3.27
0, 0, 0, 0, 126, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.91, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 3.40
0, 0, 0, 0, 131, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.95, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 2.19
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 2.50
Sending ID0...
Sensor 0 - Temp: 15.46 Hum: 98.07
0, 0, 0, 0, 137, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.69, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 1.58
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 5.04
0, 0, 0, 0, 142, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.40, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 7.17
0, 0, 0, 0, 147, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.99, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 6.93
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 4.67
0, 0, 0, 0, 152, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.30, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID0...
Sensor 0 - Temp: 15.45 Hum: 98.06
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 4.28
Sending ID3...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 3.87
0, 0, 0, 0, 157, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.08, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID5...
A2 :685 BatVolt : 13.53
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 2.51
0, 0, 0, 0, 162, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.70, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 3.29
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 4.83
0, 0, 0, 0, 167, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.34, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 4.41
Sending ID0...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 3.37
0, 0, 0, 0, 172, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.94, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 2.35
0, 0, 0, 0, 177, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.65, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.64 WindGust Km/h: 6.11
WindDir: 263 WindDirName: WSW
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 9.98
0, 0, 0, 0, 182, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.77, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 11.20
WindDir: 247 WindDirName: SW
Sending ID3...
Sending ID0...
Sensor 0 - Temp: 15.51 Hum: 98.09
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 8.92
0, 0, 0, 0, 188, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.48, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 11.55
WindDir: 274 WindDirName: W
0, 0, 0, 0, 193, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 3.21, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 11.40
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 8.79
0, 0, 0, 0, 198, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.44, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 7.17
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 5.85
0, 0, 0, 0, 203, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.62, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID0...
Sensor 0 - Temp: 15.51 Hum: 98.14
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 2.99
0, 0, 0, 0, 208, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 0.83, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 7.04
WindDir: 273 WindDirName: W
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 5.62
0, 0, 0, 0, 213, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.56, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 4.91
Sending ID3...
Sending ID2...
Wind Speed Km/h (10m Avg): 5.03 WindGust Km/h: 3.80
0, 0, 0, 0, 218, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.05, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
You don't need to write "true" for debug definitions... You only need remove "//" at the beginning of the lines. But I think the output will be the same.
In my opinion, you have almost the whole board in order, it receives, processes and sends data correctly. It is possible that the transmitter module
is not working, I would recommend replacing it.
I didn't notice which TX unit you are using, what version it is. Tell us, please. And can you post a photo of the transmitter module?
(The transmitter module should probably always have the transmitter antenna connected, it should not be running "idle".)
Yes, now I can see it - you have TX v3.12...
Picture attached. I disconnect power before disconnecting anything on the board.
The parts list i found says it should be a KXD-10036 RF Transmitter Module 433MHZ which is what i currently have and seems impossible to find.
I found a thread by Werk which references a different type of part ? link shown below :-
