AQ Software - Printable Version
+--- Thread: AQ Software (/thread-1293.html)
RE: AQ Software - Barrow4491 - 11-12-2017
(10-12-2017, 23:57)Werk_AG Wrote:
(10-12-2017, 23:48)Barrow4491 Wrote:  ... as you can see it appears to have come good after an initial error read???
 I have reloaded the software and it appears OK at the moment and i will leave it run and let you know the results
As said before, the first or second initial reads always gives a CRC error, which leads to get "Wrong reply from CO2 sensor!"
Is good to know that your back in business again.  Smile
I don’t know what the issue is or was but I suspect I will have to eventually replace the sensor.
Do you know if there is any possibility that Weather Underground will add a widget to the “WunderStation” app to allow us to add AQM?
