2PLUS_v3.2_b001 - Printable Version
+--- Thread: 2PLUS_v3.2_b001 (
/thread-1239.html)
RE: 2PLUS_v3.2_b001 -
danner - 18-09-2017
The weather station is working fine, guys. I'm simply reporting my observations on the new software version. Thanks.
hornychz - 18-09-2017
Hi again.
I saw into newest development version, which I installed yesterday, and that version
haven't option enable/disable too (I didn't notice it yesterday). It's auto enable after
enable internet, I think.
If your problem persists, it will have to help Werk_AG ...
qldbureau - 18-09-2017
I have just installed the new version. As Zdenek has said I would concur that the software version check is automatic if internet is enabled. There is code in the main routine panel which checks version if the internet is enabled.
werk_ag - 18-09-2017
Yes, that's it. Version check can only occur if Internet is enabled, and its automatic.
(18-09-2017, 07:01)danner Wrote: The internal web page System Info screen says,
"WEATHERDUINO PRO2 PLUS ™ - 2PLUS_v3.2_b001
Latest available version: 2PLUS_v3.2_b001"
but on the receiver system info page it still says "check for latest software is disabled"
other than that everything else appears to be working fine.
That is a bug, that should be corrected in b002.
Thanks for reporting it.
danner - 18-09-2017
(18-09-2017, 18:41)Werk_AG Wrote: That is a bug, that should be corrected in b002.
You're quite welcome.
danner - 19-09-2017
WeatherDuino Pro2 PLUS RX v3.2_b002 corrected the "check for latest software is disabled" issue reported above.
Everything appears to be functioning normally at this time.
Thanks.
werk_ag - 19-09-2017
Thank you for the feedback and for the very quick reaction, I really appreciate it.
For awhile should not have any new releases.
danner - 19-09-2017
(19-09-2017, 02:39)Werk_AG Wrote: Thank you for the feedback and for the very quick reaction, I really appreciate it.
