Apogee SP-110 - Printable Version
+--- Thread: Apogee SP-110 (/thread-1232.html)
RE: Apogee SP-110 - werk_ag - 18-11-2017
Apogee SP-110 installed today
Data on my live site, will continue to be from the "solar cell" pyranometer, as it is working well since almost 3 years. I will be using this one just for comparisons.
Just by curiosity, my solar panel (50W monocrystalline) and the battery (12V - 14 A/hr):
RE: Apogee SP-110 - hornychz - 18-11-2017
(18-11-2017, 20:35)Werk_AG Wrote:  Apogee SP-110 installed today
Simply perfect! Good work.
Smile
RE: Apogee SP-110 - werk_ag - 19-11-2017
Smile
Thank you. Surely you noted that, as we talked in another topic, antenna is at horizontal position.
RE: Apogee SP-110 - hornychz - 19-11-2017
Smile
Yes of course ...  Smile Smile
(My original field, which I also studied at college, is radio engineering. So now I'm happy if I can use anything.  Big Grin )
RE: Apogee SP-110 - danner - 19-11-2017
Looks great!
RE: Apogee SP-110 - zitoune - 20-11-2017
Bravo Werk! Looks great ! i remember those pictures (with no Apogee) when I started the project - i still want at some point have a solar panel and inviter to power my sensors. Maybe one day Smile
RE: Apogee SP-110 - Barrow4491 - 23-11-2017
(20-11-2017, 13:27)zitoune Wrote:  Bravo Werk! Looks great ! i remember those pictures (with no Apogee) when I started the project - i still want at some point have a solar panel and inviter to power my sensors. Maybe one day Smile
I managed to get ode of the Apogee SP110 sensors and have installed it today but am not getting any reading on my Rx.
I have checked it's output and it measures 170 mv with sun overhead and a cloudless sky. What output should i expect at A0  A1?
regards
JIm
RE: Apogee SP-110 - werk_ag - 23-11-2017
regards
JIm
Hi Jim,
Do you have the Solar / UV interface?
regards
JIm
Hi Jim,
Yes I  do, i bought the kit a couple of years ago
Before anything else, please check your user configurable settings on both TX and RX software.
TX
// -------------------------------------------------------------------------------------- //   Define which data this unit will send. 0 = Not send this data, 1= Send this data // -------------------------------------------------------------------------------------- ... #define ID4  1  // SolRad / UV data ...
RX
Suposing Solar/UV interface is connected to TX unit0
// -------------------------------------------------------------------------------------- //   Define the source of your main outside sensors // -------------------------------------------------------------------------------------- ... // ---- Define the source of your main Solar / UV sensores #define SRUV_OutUnit     0   // 0= Solar Rad / UV sensors connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // ---- Define type of Solar Radiation / UV Sensors // ---- Support for sensor type 4 its experimental (type 4 its a PAR sensor) #define Solar_Sensor     2   // 0 not used, 1= Solar Cell "Pyranometer", 2= Apogee SP-110 Pyranometer, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor ...
