sorry, this post can be deleted!
I need to do more checking before asking...
(05-05-2019, 21:26)edr1924 Wrote: I need to do more checking before asking...
I had read the post before you delete it... maybe I can help.
Things to check
- Does the system stops when the TFT is removed?
- Leave display MISO unconnected
- Start just with the BME280 (config software accordingly)
- Touch the 3.3V regulator. Is it running very hot?
Things to check
Thank you very much!,
I will check your suggestions...
But first I wanted to replace the TFT with a LCD screen to see if the system would work but now I get a compilation error ONLY WHEN I change the display type from TFT (3) to LCD (1) ...    I'm getting a bit frustrated after 10 hours debugging until very late yesterday... Confused
But... it will be solved one way or another some day, some time Big Grin
  • I use Arduino 1.8.8 on a linux system with AVR manager 1.6.21.
  • Deleted ALL libraries leaving only the libraries provided with the WD8.2_b001 download.
ReadManual
ERROR WHILE COMPILING:
/home/erik/Arduino/WeatherDuino_P2AT2560_RX_v8.2_b001/RX_TX.ino: In function 'void ReceiveDataRF()':
RX_TX:47:61: error: 'RXled_TFT' was not declared in this scope
  if (activeWindow == TXinfo_Data) RXled_TFT(TX_UnitID, true);
RX_TX:447:62: error: 'RXled_TFT' was not declared in this scope
  if (activeWindow == TXinfo_Data) RXled_TFT(TX_UnitID, false);
/home/erik/Arduino/WeatherDuino_P2AT2560_RX_v8.2_b001/Routines.ino: In function 'void RunEvery_1_Minute()':
Routines:374:42: error: 'update_BigClock' was not declared in this scope
  if (activeWindow == 8) update_BigClock();
exit status 1
Things to check
No, system continues to receive data from the TX board as seen here:
ESP8266 FW Version: AT+GMR
busy p...
Mode station OK
Multiple mux OK
Join AP failure
WiFi connection is OFF
15:36:13 - Station ID: A1  Unit ID: 0  Sensor ID: 0  Full Message: A10000,947,F77,0,0,
15:36:15 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,47E,0,
15:36:18 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,49C,0,
15:36:19 - Station ID: A1  Unit ID: 0  Sensor ID: 3  Full Message: A10003,118,0,0,0,
SystemInit2 DONE!
Mode station OK
Multiple mux OK
Join AP failure
15:36:38 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,46A,0,
15:36:40 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,42E,0,
15:36:43 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,42E,0,
15:36:46 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,44C,0,
15:36:47 - Station ID: A1  Unit ID: 0  Sensor ID: 0  Full Message: A10000,948,F6E,0,0,
15:36:49 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,44C,0,
15:36:50 - Station ID: A1  Unit ID: 0  Sensor ID: 3  Full Message: A10003,118,0,0,0,
15:36:52 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,49C,0,
15:36:55 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,49C,0,
15:36:58 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,49C,0,
15:37:01 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,474,0,
15:37:04 - Station ID: A1  Unit ID: 0  Sensor ID: 0  Full Message: A10000,947,F77,0,0,
15:37:05 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,438,0,
15:37:08 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,49C,0,
15:37:11 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,456,0,
15:37:14 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,4D8,0,
15:37:16 - Station ID: A1  Unit ID: 0  Sensor ID: 5  Full Message: A10005,0,0,0,600,
15:37:17 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,21C,0,
15:37:20 - Station ID: A1  Unit ID: 0  Sensor ID: 2  Full Message: A10002,0,0,4D8,0,
15:37:21 - Station ID: A1  Unit ID: 0  Sensor ID: 0  Full Message: A10000,946,F74,0,0,
is not connected...
did that, no change
no, can touch is without problems.
I will contact you for ordering a new RX board.
i have some cheap level shifters lying around, will test those this evening... I fear the 74AHC244 chip has failed although I removed the diode from the atmega board.   But I powered the board without the atmega to check the voltage on several points.
(06-05-2019, 13:51)edr1924 Wrote: But first I wanted to replace the TFT with a LCD screen to see if the system would work but now I get a compilation error ONLY WHEN I change the display type from TFT (3) to LCD (1) ...    I'm getting a bit frustrated after 10 hours debugging until very late yesterday... Confused
I understand your frustration, and I apologize you.
Indeed there is a compile error when the display is set to LCD. The fix on the code is quite easy. Hope the recent changes on the code haven't caused any other problem when using the LCD. Honestly I haven't tested it with an LCD display.
Here is a fix for the compile error:
Find this line:
replace with:
 #if (DISPLAY_TYPE == 3)
 #endif
then, find this line:
replace with:
  #endif
Next Pro2 PLUS software release will include these changes.
(06-05-2019, 17:49)edr1924 Wrote: i have some cheap level shifters lying around, will test those this evening... I fear the 74AHC244 chip has failed although I removed the diode from the atmega board.   But I powered the board without the atmega to check the voltage on several points.
On most of the reported issues of white screen on the TFT, we found that they were related to the 74AHC244 chip, so I believe your deduction is right. Its hard to say what caused a failure on the chip, but they are quite sensitive, specially to static.
As said by PM, a solution is on the way to you.
Like One of the things that make this project so amazing is the support,
thank you very much...
BTW: I think most people will use a TFT screen, maybe the LCD part could be obsolete in future updates?
That would make it easier for you on the software part.
My TFT screens were 7 euro each so it's not a money issue.
Finding the right ones is. Wink
while waiting for the replacement buffer chip I took the mega board out and connected all with BB wires and some transistor level shifters. could not resist trying this... Tongue
The good news is that the display does work this way!
On the removed, broken 74AHC244 pins 5,6 and 7 were shorted together internally also pins 13 and 14 were connected.
So the cause is obvious although the system is still behaving very strange.
When I receive the new chip, I will replace the mega board also because the system is not behaving as it should.
to be continued!
One extra thing to update:
after changing the two instances you mentioned I got this error, so I also added the lines if displaytype == 3 etc. there
now it's compiling Smile
exit status 1
came across another error message:
When I set EASYWEATHER_OUT to 1, I get this compilation error
/home/erik/Arduino/WeatherDuino_P2AT2560_RX_v8.2_b001/easyweather.ino: In function 'void easyweather_Output()':
easyweather:8:16: error: 'ComLed_PIN' was not declared in this scope
  digitalWrite(ComLed_PIN, HIGH);
exit status 1
