WeeWx extra data plugin
Hello everybody,
Finally it's the time to release the first (beta) version for the WeeWx WeatherDuino Logger plugin.
This plugin for WeeWx allows you to get all extra data like snow height, AQM data or any extra sensors in full precision to WeeWx weather software.
[Image: y4mj7v7r65wBJP5QK31hcW2xVDKwW6Z-tDctpNcs...pmode=none]
The principle is very easy, the WeatherDuino logger plugin writes each minute a WeeWx export text file with your desired values. The WeeWx plugin reads this file, checks its currency, and saves it to the WeeWx database.
Attention: The plugin was tested with the Database to use metric units, I don't know what happens if your database uses US units (default).
Please read the included manual carefully. Since the plugin is in a beta stadium, all preconditions have to be like in the test environment, otherwise WeeWx might crash.
Don't forget to make some backups before  Smile
Best regards,
Attached File(s)
.zip   WeeWx_WeatherDuino_Logger_plugin_04.zip (Size: 898,01 KB / Downloads: 5)
Sounds excellent engolling, I look forward to trying it out when your work is done  Smile
www.41south.net.nz powered by WeatherDuino and Weewx
Happy New Year engolling, is there any release of this plugin yet? Looking forward to adding more data to my Weewx installation.
Colin
(10-01-2019, 22:45)41south Wrote: Happy New Year engolling, is there any release of this plugin yet? Looking forward to adding more data to my Weewx installation.
Colin
Hi Colin,
happy new year  Smile .
I think I will have the first beta ready in the next 24 hours. I'm doing final tests at the moment.
My hope was to get things done between Christmas and New Year, but there were so much other things to do …
So I had to work on it again after getting home the last and this week.
Best regards,
I could not finish the plugin completely, still have problems with the temperature unit at the moment but most of the stuff is already running, I will continue tomorrow  Smile .
Best wishes,
All good things take time Smile
Updated the first post with the beta release.
It works for me so far, but I have still some trouble with the temperature units. When I'm trying to implement Farenheit and deg Celsius for the same unit group, strange things happens.
So for the moment my database is in "metric" units and everything is tested only with metric units. I do not know what happens in other cases.
Best regards,
(13-01-2019, 18:40)engolling Wrote: Updated the first post with the beta release.
Best regards,
My database too is metric units so I will try it shortly.
Many thanks for the work on this
Engolling, have I missed the file download somewhere?
(14-01-2019, 03:35)41south Wrote: Engolling, have I missed the file download somewhere?
Nope… forgot the attachment.  Blush
