Weatherduino Pro2 v.2.0 Humidity error
I use Weatherduino Pro2 under v.2.0 b011 firmware. External humidity&temperature sensor is SHT11. While the weather is so rainy Weatherduino Pro2 shows the humidity as 6550.9 ! (The sensor is in a direct water protected enclosure )
I think there is a bug/error etc.  What can I do?
Regards.
(23-10-2018, 11:42)hamix Wrote: Hi,
Regards.
Try replacing the SHT11, preferrably with a SHT31 (I've just been told this same thing the other day by Werk Smile )
Regards.
Seems you are using a very old software version. Latest version for the Pro2 system is v4.0 released on 2018-03-27
Please upgrade your system (RX and TX) to latest software.
(23-10-2018, 17:55)Werk_AG Wrote: Hi,
I've tried. But compiling was unsuccessful. Under windows7 64 bit, try to compile with Arduino IDE 1.8.7
The error message is:
WeatherDuino_P2AT328_RX_v4.0_b001:326:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
Suggestions please.
I'm also using W7 64 bits, so this isn't the problem.
Please make sure you are using the LiquidCrystal_I2C included in the software package and not any other, older or newer.
Check C: \ user \ .. \ AppData \ Local \ Arduino
(25-10-2018, 22:17)Werk_AG Wrote: Hi,
Thanks for replies.
@Werk_AG
That's correct. Your LCD I2C library solved the problem. Aynway, I was away for a long time from this forum so I wonder if the SW version 4.0 is compatible with the Weatherduino Pro2 hw? (RX ver. 4.03 and TX ver.2.5)
@uncle_bob
I'll try replacing the SHT11 firstly with another SHT11 and then  with a SHT31.
(26-10-2018, 19:59)hamix Wrote: Hi,
Thanks for replies.
@Werk_AG
Yes, it is.
