WeatherDuino Pro2 v1.5 - Release Annoucement
A release date is not defined yet, but the new WeatherDuino Pro2 v1.5 software, should be released early in September 2015.
Version 1.5 keeps all the functionalities of the previous 1.4 version, but brings support for a whole new range of weather instruments., as also to virtually all tipping bucket based rain gauges.
Here is a list of the currently supported weather instruments.
Wind Speed sensors
Standard FO anemometers
FO anemometer modified with 1 hall effect sensor
--- Inspeed Anemometers ---
Inspeed Vortex, digital 8 pulse revolution
Inspeed Vortex, hall efect sensor - (experimental)
Inspeed Vortex, read switch sensor - (experimental)
--- Davis Anemometers ---
Davis 6410 anemometer
--- Novalynx Anemometers ---
Novalynx, model 200-WS-02F - (experimental)
EML, model WSD1 - (experimental)
DIDCOT, model DWR205
Wind Direction Sensors
--- Fine Offset Wind Vane ---
Standard FO wind vane
--- Inspeed Wind Vane ---
Inspeed E-Vane 2
--- Davis Wind Vane ---
Davis 6410 and 7911 wind vane
DIDCOT, model DWD205
Tipping Bucket Rain Gauges
--- Wired Models ---
- Fine Offset (PCE, Watson, etc)
- Davis 7852
- Texas Electronics, model 525
- Virtually, any tipping bucket rain gauge
--- Wireless Models ---
- Auriol H13726
- Ventus W155
- Hama EWS 1500
- Meteoscan w155 w160
- Alecto WS-3500
- Balance RF-WS100
Outside Temperature / Humidity Sensors
- All SHT2x series from Sensirion
- All SHT1x series from Sensirion
- HTU21D
- DHT21 or DHT22 (low end sensors)
The WeatherDuino Pro2 system works now with almost all of the more common weather instruments, making of it an universal system.
From low cost to high end weather instruments, you are free to decide, what instruments and brands you want to use, and the ones that most fit your requirements or budget.
All this, with just one upgradable and well supported software / hardware platform, already used by over a hundred people in several countrys and climates: WeatherDuino Pro2 - Making sense, with the weather.
Werk_AG muchas gracias por el esfuerzo, estaremos atentos.
Saludos
As promised, it's already available!
To download click here.
I wish to give a special thank you to JT118 for given the help with the tests for the Didcot and Davis wind instruments, and some others weather instruments too... without him, this release would take much much longer to be available.
A note too, for Denis Bill, which offered his help to test the Davis rain gauges. Thank you, too.
(03-09-2015, 00:40)Werk_AG Wrote:  I wish to give a special thank you to JT118 for given the help with the tests for the Didcot and Davis wind instruments, and some others weather instruments too... without him, this release would take much much longer to be available.
Great work by all involved!
