WeatherDuino 4Pro Wireless Display - Presentation
New and powerful WiFi WeatherDuino Wireless Display units.
[Image: WeatherDuino_4Pro_WD_ESP8266_01_web.jpg]
Unit was designed to be like a back pack for the TFT display...
[Image: WeatherDuino_4Pro_WD_ESP8266_02_web.jpg]
board is the same size and same colour as the TFT display...
[Image: WeatherDuino_4Pro_WD_ESP8266_04_web.jpg]
the result is a extremely compact and solid unit...
which keeps the same look and feel of the Pro2 PLUS system...
Latest software use smooth fonts and support accented characters on the user interface
Supplied fully assembled and ready to work (includes the TFT Display).
See it in action...
https://www.meteocercal.info/forum/video...8266_2.mp4
Note: This video was done from an unit running an older software version, current software version uses smooth fonts and a new set of icons.
Looks wonderful but half the fun is constructing it yourself. I hope you will be offering the board only as well?
(11-04-2018, 08:46)Barrow4491 Wrote: Werk,
Hi Jim,
I agree with you, building things is part of the fun, however this unit will be available as a fully assembled device only and in limited quantities.
User only needs to program it and it is ready to use. Software upgrades can even be made by OTA, without having to remove the device from where it is installed (supposing the user enabled the WiFi capabilities of the device).
Hi Jim,
Werk
Have you any idea of the cost and an the timing?
Hi Jim,
Werk
The cost will be less than buying all the parts required to build the previous version, and you don't need to worry about buying the correct type of TFT screen.
First batch should be available to order in the next days.
Very nice unit Werk_AG!
Good work!
Will it be compatible with Weatherduino Pro2 or Pro2 Plus only?
(12-04-2018, 06:34)MikeM Wrote: Very nice unit Werk_AG!
Good work!
Hi Mike,
I can confirm full compatibility with Pro2 PLUS.
Good work!
Hi Mike,
It is compatible with both Pro2 and Pro2 PLUS systems running latest software.
Indeed it is a fantastic add-on for Pro2 users, which only have an LCD display. With the addition of one (or more) Wireless Display devices, Pro2 users will benefit of a touch color TFT display.
Air Quality data only available with Pro2 Compact or Pro2 PLUS receivers.
New software available: WeatherDuino 4Pro Wireless Display v3.0_b006 - 2018-04-24
Only a few units available of first batch. Hurry up if you want to get one.
Is it available now? at what price?
