WeatherDuino_4PESP8266_WD_v5.0_b009
This latest software version references the language files as per previous versions e.g.
en_GB.h
However the actual file names in the folder _lang have changed to en_GB_UTF8.h the code in Config_options needs changing as per below to avoid a compilation error..
#include "_lang/en_GB_UTF8.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end
Other than that all seems good so far
Andy
Hello Andy, sorry to say, but that isn't correct.
On the Config_Options for the latest WeatherDuino_4PESP8266_WD_v5.0_b009 software you only need to define the language code
//   Define User Interface Language
//             Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL, it_IT, pl_PL
#define en_GB
The software will select the correct language file based on the language code.
(21-03-2019, 19:36)Werk_AG Wrote: Hello Andy, sorry to say, but that isn't correct.
#define en_GB
Ah all is clear now! I must have slipped up when copying by config data across from the previous version of the software, thans for correcting me & for the great improvements to this version..
Andy
Smile Thank you.
