Waterproofing?
Hi all.
If this question has been asked before, please accept my apologies, i have a UV30A UV sensor, the fact that it is a UV sensor means it must be outdoors exposed to the elements, my problem is can i make it waterproof without effecting the readings? is there a product out there i can cover it with, which does not block UV rays?
Ray
Fused silica is a good material in terms of UV transparency.
It is here;
https://www.ebay.co.uk/itm/Double-Sided-...3222202354?
