I'm busy installing the fantastic new AQMIII but the SDS011 sensor refuses to cooperate even after putting it for a full hour in a microwave.
Anyways, the SDS011 does work on it's own with a generic library so I know it's not broken.
I do use the right software: IDE 1.8.15 and ESP32 1.06
Board selected in the IDE: LOLIN 32
The ESP32 is connected to the USB and a separate 5V power supply
(so I don't understand the brownout message)
I noticed that the fan of the SDS011 is not running and the LED only blinks ever ~8 sec.
Below the serial monitor output... and the Config.h file contents:
this is the Config.h file:
18:41:03.051 -> e⸮#ka+⸮⸮!H⸮⸮K⸮⸮⸮i⸮-⸮-⸮⸮vi!-⸮'⸮⸮#i!⸮⸮)⸮⸮⸮⸮⸮⸮ WeatherDuino 4Pro
18:41:03.383 -> Air Quality Monitor III
18:41:03.383 -> Firmware: 6.1_b005
18:41:03.383 ->
18:41:03.880 -> Initializing the SDS011 sensor!
18:41:03.880 ->
18:41:04.908 -> 0,0,0,0,0,0,0,0,0,0
18:41:04.908 -> Calculate crc: 0
18:41:04.908 -> Response crc: 0
18:41:04.908 -> SDS011 correctly set to active report mode.
18:41:04.908 ->
18:41:06.434 -> 0,0,0,0,0,0,0,0,0,0
18:41:06.434 -> Calculate crc: 0
18:41:06.434 -> Response crc: 0
18:41:06.434 -> SDS011 correctly set to factory working period.
18:41:06.434 ->
18:41:06.434 ->
18:41:06.434 -> Connecting to anJe!
18:41:06.500 ->
18:41:06.500 -> Brownout detector was triggered
18:41:06.500 ->
18:41:06.500 -> ⸮I
18:41:06.500 -> ⸮:⸮C⸮;{ck⸮⸮⸮⸮K`⸮b)⸮) aHh⸮i%=Z⸮$+⸮)HF⸮(!⸮"⸮#⸮ WeatherDuino 4Pro
18:41:06.865 -> Air Quality Monitor III
18:41:06.865 -> Firmware: 6.1_b005
18:41:06.865 ->
18:41:07.329 -> Initializing the SDS011 sensor!
18:41:07.329 ->
18:41:08.358 -> 0,0,0,0,0,0,0,0,0,0
18:41:08.358 -> Calculate crc: 0
18:41:08.358 -> Response crc: 0
18:41:08.358 -> SDS011 correctly set to active report mode.
18:41:08.358 ->
18:41:09.883 -> 0,0,0,0,0,0,0,0,0,0
18:41:09.883 -> Calculate crc: 0
18:41:09.883 -> Response crc: 0
18:41:09.883 -> SDS011 correctly set to factory working period.
18:41:09.883 ->
18:41:09.883 ->
18:41:09.883 -> Connecting to anJe!
18:41:10.082 -> ......................
18:41:12.271 -> WiFi connected!
18:41:12.271 -> IP address: 192.168.1.88
18:41:12.436 -> Get time OK.
18:41:12.436 -> UTC Time : 1628527272
18:41:12.436 -> Local Time: Monday, 09 August 2021 17:41:12
18:41:12.436 -> Reading Temp, Hum and Pressure
18:41:12.436 -> Temperature: 25.36
18:41:12.436 -> Humidity: 52.99
18:41:12.436 -> Amb. Pressure: 1015.48
18:41:12.436 -> SL Pressure: 1015.59
18:41:12.436 ->
18:41:12.436 -> Setting measurement range to: 5000
18:41:12.436 -> FF,99,1,0,0,0,0,0,66,
18:41:12.436 -> 66,66
18:41:12.436 -> Measurement range changed!
18:41:15.388 -> Enabling ABC
18:41:28.389 -> Initial reading: 1
18:41:29.450 -> F8,FE,1E,FB,3F,68,2E,FC,3F,
18:41:29.450 -> Calculated crc: 18
18:41:29.450 -> Wrong reply from CO2 sensor!
18:41:29.450 ->
18:41:35.418 -> Initial reading: 2
18:41:35.485 -> FF,86,1,F4,49,0,0,0,3C,
18:41:35.485 -> Calculated crc: 3C
18:41:35.485 -> CO2 RAW: 500
18:41:35.485 -> CO2 Comp: 499
18:41:35.485 -> Z19 Temp: 33
18:41:35.485 ->
18:41:41.453 -> Initial reading: 3
18:41:41.519 -> FF,86,1,F4,4A,0,0,0,3B,
18:41:41.519 -> Calculated crc: 3B
18:41:41.519 -> CO2 RAW: 500
18:41:41.519 -> CO2 Comp: 499
18:41:41.519 -> Z19 Temp: 34
18:41:41.519 ->
18:41:47.485 -> Initial reading: 4
18:41:47.551 -> FF,86,1,F4,4A,0,0,0,3B,
18:41:47.551 -> Calculated crc: 3B
18:41:47.551 -> CO2 RAW: 500
18:41:47.551 -> CO2 Comp: 499
18:41:47.551 -> Z19 Temp: 34
18:41:47.551 ->
18:41:53.518 -> Initial reading: 5
18:41:53.551 -> FF,86,1,F4,4A,0,0,0,3B,
18:41:53.551 -> Calculated crc: 3B
18:41:53.551 -> CO2 RAW: 500
18:41:53.551 -> CO2 Comp: 499
18:41:53.551 -> Z19 Temp: 34
18:41:53.551 ->
18:41:59.520 -> Initial reading: 6
18:41:59.586 -> FF,86,1,F4,4A,0,0,0,3B,
18:41:59.586 -> Calculated crc: 3B
18:41:59.586 -> CO2 RAW: 500
18:41:59.586 -> CO2 Comp: 499
18:41:59.586 -> Z19 Temp: 34
18:41:59.586 ->
18:42:05.554 -> Initial reading: 7
18:42:05.620 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:05.620 -> Calculated crc: 3B
18:42:05.620 -> CO2 RAW: 500
18:42:05.620 -> CO2 Comp: 499
18:42:05.620 -> Z19 Temp: 34
18:42:05.620 ->
18:42:11.587 -> Initial reading: 8
18:42:11.620 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:11.620 -> Calculated crc: 3B
18:42:11.620 -> CO2 RAW: 500
18:42:11.620 -> CO2 Comp: 499
18:42:11.620 -> Z19 Temp: 34
18:42:11.620 ->
18:42:17.586 -> Initial reading: 9
18:42:17.652 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:17.652 -> Calculated crc: 3B
18:42:17.652 -> CO2 RAW: 500
18:42:17.652 -> CO2 Comp: 499
18:42:17.652 -> Z19 Temp: 34
18:42:17.652 ->
18:42:23.621 -> Initial reading: 10
18:42:23.687 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:23.687 -> Calculated crc: 3B
18:42:23.687 -> CO2 RAW: 500
18:42:23.687 -> CO2 Comp: 499
18:42:23.687 -> Z19 Temp: 34
18:42:23.687 ->
18:42:29.654 -> Initial reading: 11
18:42:29.687 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:29.687 -> Calculated crc: 3B
18:42:29.687 -> CO2 RAW: 500
18:42:29.687 -> CO2 Comp: 499
18:42:29.687 -> Z19 Temp: 34
18:42:29.687 ->
18:42:35.653 -> Initial reading: 12
18:42:35.719 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:35.719 -> Calculated crc: 3B
18:42:35.719 -> CO2 RAW: 500
18:42:35.719 -> CO2 Comp: 499
18:42:35.719 -> Z19 Temp: 34
18:42:35.719 ->
18:42:41.687 -> Initial reading: 13
18:42:41.753 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:41.753 -> Calculated crc: 3B
18:42:41.753 -> CO2 RAW: 500
18:42:41.753 -> CO2 Comp: 499
18:42:41.753 -> Z19 Temp: 34
18:42:41.753 ->
18:42:47.722 -> Initial reading: 14
18:42:47.755 -> FF,86,1,F4,4A,0,0,0,3B,
18:42:47.755 -> Calculated crc: 3B
18:42:47.755 -> CO2 RAW: 500
18:42:47.755 -> CO2 Comp: 499
18:42:47.755 -> Z19 Temp: 34
18:42:47.755 ->
18:42:53.757 -> Init MH-Z19 Ended
18:42:53.757 ->
18:42:53.757 ->
18:42:53.757 -> Waking up the dust sensor...
18:42:53.757 -> Reading will be done 40s later.
18:42:53.757 ->
18:43:22.362 -> Reading Temp, Hum and Pressure
18:43:22.362 -> Temperature: 25.36
18:43:22.362 -> Humidity: 52.99
18:43:22.362 -> Amb. Pressure: 1015.47
18:43:22.362 -> SL Pressure: 1015.59
18:43:22.362 ->
18:43:33.733 -> Fan State: 1
18:43:33.733 -> Reading the dust sensor...
18:43:34.827 -> D,80,70,1F,FB,3F,68,2E,FC,3F,
18:43:34.827 -> Calculate crc: 5F
18:43:34.827 -> Response crc: FC
18:43:34.827 ->
18:43:34.827 -> Wrong reply from SDS011 sensor!
18:43:34.827 -> FF,86,2,82,49,0,0,0,AD,
18:43:34.827 -> Calculated crc: AD
18:43:34.827 -> CO2 RAW: 642
18:43:34.827 -> CO2 Comp: 641
18:43:34.827 -> Z19 Temp: 33
18:43:34.827 ->
18:43:34.827 -> CO2 1H Avg: 641
18:45:32.352 -> Reading Temp, Hum and Pressure
18:45:32.352 -> Temperature: 25.36
18:45:32.352 -> Humidity: 52.72
18:45:32.352 -> Amb. Pressure: 1015.46
18:45:32.352 -> SL Pressure: 1015.58
18:45:32.352 ->this is the Config.h file:
// WeatherDuino - Air Quality Monitor III v6.1_b005
// User Configurable Options
// Define StationID of this device - Used when sending data by RF to a compatible WeatherDuino receiver
const byte Station_ID = 0xA1; // Must be equal to your RX Unit (Value from 0x00 to 0xFF)
const byte Unit_ID = 0; // 0 or 1
// Define a unique ID for each AQM unit (used to identify unit for OTA upload). No spaces or special chars.
const char* Device_Name = "My_AQM";
// Location Elevation
#define ELEVATION 1 // Define the height above sea level of the place where sensor is installed (value in Meters without decimal places)
// Define type of Dust sensor
#define DUST_SENSORTYPE 1 // 0= PMS7003, 1= nova SDS011, 2 = Sensirion SPS30 (working in I2C mode)
// The settings bellow, define the Air Quality Standard and Average Mode that will be used to calculate the Air Quality Index show on the OLED display, if used.
// If this unit is used to send data by RF (OOK only) to a Pro2 PLUS or Pro2 Compact receiver, then the PRO2_MODE setting SHOULD be set to 1,
// and other settings will define the AQI Standard and Average Mode that is sent to Pro2 PLUS and Pro2 Compact receivers.
// Settings on the receiver, MUST match the settings defined here.
// If this unit is used to send data (RF or WiFi) to a 4Pro receiver, then the PRO2_MODE setting SHOULD be set to 0.
// With WeatherDuino 4Pro receivers the AQI Standard and Average Mode is set on the receiver,
// and can be different of the settings defined here.
#define AQI_STANDARD 1 // 0= USA (AQI-EPA), 1= EUROPE (EAQI), 2= UK (DAQI), 3= AUSTRALIA (AQC - NSW)
#define AQ_AVGMODE 2 // 1= 1 Hour Average, 2= 3 Hours Average, 3= Nowcast 12H, 4= 24 Hours Average
#define PRO2_MODE 1 // 0= Use 0 to send data to 4PRO receivers, 1= Compatibility mode for Pro2 PLUS and Pro2 Compact receivers
// Define type of CO2 sensor
#define CO2_SENSORTYPE 2 // 0= Not instaled, 1= Sensirion SDC30, 2= MH-Z19
// Settings for the Sensirion SCD30 - CO2 Sensor
// The sensirion SDC30 compensate the CO2 readings by using one of two methods: Atmospheric Pressure or a fixed Altitude value.
// Define bellow which one you want to use.
#define SDC30_ELEVATION_CALIBRATION_METHOD 0 // 0= Elevation defined above, 1= Atmospheric Pressure from BME280 sensor (overrides ELEVATION)
// If the SDC30 is intalled, system will use its high quality built-in Temperature / Humidity sensor. BME280 will be used only for Atmospheric Pressure.
// Optionally we can set a temperature offset up to 5.0 °C, stored in non-volatile memory of SCD30
const float SCD30_TemperatureOffset = 2.0; // Format: float
// Settings for the MH-Z19 - CO2 Sensor
#define Z19_MODEL 2 // 1= Model A, 2= Model B (ATTENTION: Make sure you select the correct model)
#define ENABLE_ABC 1 // 0= Disable (Better for outdoor use), 1= Enable
// Set measure range
#define Z19_RANGE 5 // Don't change (Keeps default factory range 0..5000 ppm)
// Valid values for Model A: 1= 1000ppm, 2= 2000ppm, 3= 3000ppm, 5=5000ppm
// Valid values for Model B: 2= 2000ppm, 5= 5000ppm
const int16_t CO2_OffSet = 0; // Fine adjust to compensate sensor error (This value should be determined case by case. Values between -50 and 50)
// Temperature Offset
// Note: Applies only when not using the Sensirion SCD30 CO2 sensor!
const float Temperature_Offset = 0; // Temperature Fine Adjust in ºC
// Define use of OLED Display
#define USE_DISPLAY 0 // 0= No Display, 1= Use Display
// Define use of LED 1 (Led will Fade IN / Fade OUT sinalizing system is running)
#define LED_FADE_EFFECT 1 // 0= No, 1= Yes
// Enable / Disable RF data transmission
#define RF_TXMODE 2 // 0= No data will be transmitted via RF, 1= Transmit LoRa Mode (4Pro Receivers), 2= Transmit OOK Mode (Pro2 Receivers)
// The WeatherDuino AQM-III can work with or without WiFi connection, however
// many of its functions, like OTA programming, system clock, data upload and others
// will only work if there is WiFi connection.
// Enable / Disable WiFi connection
#define ENABLE_WIFI 1 // 1= Enable, 0= Disable
// Functions from this point bellow only work with WiFi connection active
// Define Timezone and rules for auto Summer Time clock adjust
// System can use POSIX standard format, or a simpler format.
// Choose and set the one you prefer
// Examples:
// In North American Eastern Standard Time (EST) and Eastern Daylight Time (EDT), the normal offset from UTC is 5 hours.
// Since this is west of the prime meridian, the sign is positive (+5 = 5).
// Summer time begins on March’s second Sunday at 2:00am, and ends on November’s first Sunday at 2:00am.
// TZ_info = "EST+5EDT,M3.2.0/2,M11.1.0/2"
// Western Greenland Time (WGT) and Western Greenland Summer Time (WGST) are 3 hours behind UTC in the winter.
// Its clocks follow the European Union rules of springing forward by one hour on March’s last Sunday at 01:00 UTC (-02:00 local time)
// and falling back on October’s last Sunday at 01:00 UTC (-01:00 local time).
// TZ_info = "WGT3WGST,M3.5.0/-2,M10.5.0/-1"
//const char* TZ_info = "CET-1CEST,M3.5.0/2,M10.5.0/3"; // --> France Timezone
//const char* TZ_info = "AZOT1AZOST,M3.5.0/01:00:00,M10.5.0/02:00:00"; // --> Açores, Portugal Timezone
const char* TZ_info = "WET0WEST,M3.5.0/01:00:00,M10.5.0/02:00:00"; // --> Portugal Timezone
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 3600;
#define TIMEZONE_DEFTYPE 0 // 0= POSIX, 1= Simple GMT Offset and Summer Time Offset
// Prefered NTP Server - Enable only one
#define TIMESERVER "pool.ntp.org"
//#define TIMESERVER "time.nist.gov" // ntp1.nl.net NTP server
// Defines port used by the buil-in webserver
// Buil-in webserver provides a way to quickly view Air Quality data on a web browser.
// Ex: 192.168.1.200/aqnow
#define WEBSERVER_PORT 80 // WebServer port (default 80)
// Enable / Disable data transmission to sensor.community
// The AQM-III allows you to share Air Quality data from your location, with the sensor.community project.
// Your sensor and data will be show on a map: https://maps.sensor.community/#2/0.0/0.0
// Just register your sensor at https://devices.sensor.community/ and add your Sensor_UID to Credentials
#define ENABLE_SC_UPLOAD 0 // 1= Enable, 0= Disable
// Enable / Disable data transmission to ThingSpeak
#define ENABLE_TS_UPLOAD 0 // 1= Enable, 0= Disable
// Air Quality Monitor - Upload and insert data in a SQL table at your own server ----
// Be sure you have already created the database and table. See AirQuality_LogToSQL.php script for info
#define ENABLE_AQM_TO_MYSERVER 0 // 1= Enable, 0= Disable
// Hardware Settings - Most likely there is no need to change anything here
// OLED I2C Address - Default address will work most of the times!
#define OLED_address 0x3C
// Board Type
#define PCB_TYPE 1 // 1= Don't change !!!
// Debug helper - Uncomment for debug help
#define PRINT_DEBUG_WIFI
#define PRINT_DEBUG_SYNCTIME
#define PRINT_DEBUG_DUSTSENSOR
#define PRINT_DEBUG_CO2
#define PRINT_DEBUG_TH_SENSOR
#define PRINT_DEBUG_TS_UPLOAD
#define PRINT_DEBUG_MYSERVER_UPLOAD
#define PRINT_DEBUG_SENSORCOMMUNITY
