Pro2 v2.0 b011 Upgrade
Quote:I am really puzzled because my RX and TX are 2 meters apart; and before it was working very well..
At first sign it seems just a problem with the RF transmission. Two meters between the transmitter and the receiver, may be a very short distance, which can block the receiver. The first thing I would try is putting the RX unit some meters away, or for testing you could also try remove the receiver antenna on the RX unit.
Let me know the results...
Quote:Now, when powering the RX and TX I cannot get the 3 digits of the welcome message set to 1 altogether. Rather I see 110, or 011, and it takes ages to get those values! It never happened before..
When the third "1" comes, the LCD display jumps to showing data, so usually it's hard to see all three "ones" together". But, as you know, it shouldn't take more than 1 to 2 minutes to happen.
Thanks Werk. I moved away the RX, tried a different room as well, and also removed the RX antenna as suggested. When I reboot the board, I still see 000 for more than 2 min.
I will let it run during the night and will see.
What about the temperature sensor? Could it be it to prevent the TX to work properly?
Thanks.
(07-08-2016, 16:28)zitoune Wrote:  Thanks Werk. I moved away the RX, tried a different room as well, and also removed the RX antenna as suggested. When I reboot the board, I still see 000 for more than 2 min.
Thanks.
The inside temperature sensor is read only after the initialization process, so for now we should focus in discover why the RX unit is not receiving data from the three main sensors.
Next things to check / try:
Check if you have defined the correct board version in the RX software
Quote:// ---- Define your RX board, main version number
#define Board_Version 6 // 6 for all RX boards v6.xx, 5 for all RX boards v5.xx, 4 for all RX boards v4.xx
I think your RX board is a v4.xx or a v5.xx
Try to run the RX unit in test mode.
Quote:// --------------------------------------------------------------------------------------
// Test Mode : Never run a live system in test mode
#define TestMode false // false or true
Do you see any data from the outside sensors on the LCD display?
Continue running the RX unit in test mode, and on the TX software enable sending just one type of sensor at a time...
// Define which data this unit will send. 0 = Not send this data, 1= Send this data
#define ID0 1 // Temp/Hum Data
#define ID1 0 // Not Used
#define ID2 0 // Wind data
#define ID3 0 // Rain data
#define ID4 0 // UV / SolRad data
#define ID5 0 // Hardware Status - System Temp, Battery Voltage etc
#define ID7 0 // Send Soil & Leaf Temperature Data
#define ID9 0 // Send Soil & Leaf Moisture / Wetness Data
Repeat procedure for Wind, and Rain, one at the time. Is the TX led on the TX unit blinking for each type of sensor?
Could you please post your Config_RX.ino and Config.TX.ino files?
Another important thing. If you are using the Inspeed E-Vane, the JP2 jumper on the TX board should be keep open.
(08-08-2016, 01:00)Werk_AG Wrote:  The inside temperature sensor is read only after the initialization process, so for now we should focus in discover why the RX unit is not receiving data from the three main sensors.
OK
Yes it was properly setup to 4.
No - nothing more than the internal sensors (Temp/Hum and Atm). No info from the TX system either.
Quote:Could you please post your Config_RX.ino and Config.TX.ino files?
Here you go:
//   User configurable options
//   Define ID's for this weather station
#define Station_ID     0xA1   // Station_ID, use the same value in all TX units
#define Relay_ID       0xA3   // Relay_ID,   use the same value in all WD units
//   Define your Weather Station location
#define LATITUDE      1,278    // Put here your Station latitude in tenths of degrees North
#define LONGITUDE     103,788    // Put here your Station longitude in tenths of degrees (minus for West)
#define ELEVATION     8    // Put here your Station height above sea level in Meters
//   Define Roll Over Hour for Meteorological Day
#define MeteoDay_HStart   0   // Use values from 0 to 23
//   Define Software Operation Mode
#define Work_Mode         0   // Mode 0= Davis VP2 Emulation Mode, Mode 1= EasyWeather Mode
//   Define your Display type
#define DisplayType       0   // 0= LCD 20x4, 2= LCD 16x2
//   Define Display Backlight TimeOut
// ---- For old RX boards, version <= 3.01 always set this value to 0
const byte  BackLight_Timeout =  2;   // Timeout for display backlight in minutes (1 to 255). 0 = Always ON
//   Define data display units
#define Date_Time_Format    0    // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd
#define Temp_Display_Unit   0    // 0 for ºC, 1 for ºF
#define ATM_Display_Unit    0    // 0 for mBar, 1 for inHg
#define Rain_Display_Unit   0    // 0 for mm (no other options)
#define Wind_Display_Unit   0    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots
//   Fine adjusts for Inside Temperature and Barometer
const int   TemperaturaInt_offset =  0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC)
const float SeaLevel_ATM_offset   =  0;   // Pressure Fine Adjust in mB
//   Define Wind Speed and Wind Gust resolution
#define VP2_WindRes     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h (limite 183.6 Km/h)
                             // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h (limite 91.8 Km/h)
                             // This setting only have effect when the software is used in Davis VP2 emulation mode
                             // If set to 0, system uses Standard Davis 1 mph wind resolution (limite 241 Km/h).
//   Define use of Wind Gust Spike prevention routines
#define WindSpikeControl 1   // 0= Disable, 1= Enable method 1, 2= Enable method 2
//   Define the type of your inside Temperature / Humidity Sensor
#define InsideTH_Sensor  0   // 0= DHT22, 1= HTU21D
//   Define the type of your outside Temperature / Humidity Sensor
#define MainOutTH_Sensor 0   // 0 for sensor type SHT31, SHT2x or HTU21D, 1 for sensor type SHT1x or DHT22 (Always 0 when working with Auriol and clones)
//   Define the source of your main outside sensors
// ---- If you have all the sensors connected to only one TX board, always select Unit 0 as source
// ---- Define the source of your main Temperature / Humidity sensor
#define TH_OutUnit       0   // 0 for Temp/Hum sensor connected to TX_Unit 0, 1 for Temp/Hum sensor connected to TX_Unit 1, 3 for Auriol RF Wind Speed
// ---- Define the source of your Main Wind sensor
#define WIND_OutUnit     0   // 0 for Wind instruments connected to TX_Unit 0, 1 for TX_Unit 1, 3 for Auriol RF Wind Dir
// ---- Define the source of your main Rain Gauge
#define RAIN_OutUnit     0   // 0 for Rain Gauge connected to TX_Unit 0, 1 for TX_Unit 1, 3 for Auriol RF Rain Gauge
// ---- Define the source of your main Solar / UV sensores
#define SRUV_OutUnit     9   // 0 for Solar Rad / UV sensors connected to TX_Unit 0, 1 for TX_Unit1, 9 for not used
// ---- Define installed Solar / UV Sensors
#define Solar_Sensor     0   // 0 for not present; 1 for present
#define UV_Sensor        0   // 0 for not present; 1 for present
#define UV_Transmission 70   // UV Transmission percentage of UV sensor cover material
//   Extra Sensors Settings and Mapping
// ---- Define the TX source and sensor number of each of the five extra sensors, insert 9 if not used.
// ---- Source 0 (up to 2) means TX unit0, 1 means TX unit1... (sensor type SHT21 or HTU21D is number 0, sensor type SHT1x or DHT22 is number 1)
// ---- First field is Source = TX unit number, Second field = Sensor number (0 or 1) in the TX unit
// ---- Example: {0,1} - First extra sensor, is sensor 1 from TX unit0
//               {1,0} - Second extra sensor, is sensor 0 from TX unit1
//-----                        ES1   ES2   ES3   ES4   ES5
#define ExtraSensors_Source { {9,9},{9,9},{9,9},{9,9},{9,9} }
//   ADVANCED FEATURE - Soil / Leaf Interface Settings
#define SoilLeaf_Interface 0  // 0= Not used, 1= In use
// ---- Soil & Leaf Sensors Mapping
// ---- Use the same logic than for Extra Sensors
// ---- As source use the TX Unit number where the Soil / Leaf is connected
// ---- For an unused sensor use 9 in both fields
//                                 S1    S2    S3    S4
#define SoilTempSensors_Source  { {1,0},{9,9},{9,9},{9,9} }
#define LeafTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} }
#define SoilMoistSensors_Source { {1,0},{9,9},{9,9},{9,9} }
#define LeafWetSensors_Source   { {1,1},{9,9},{9,9},{9,9} }
// Define VWC calculation method
// Method 1 applies only for VH400 soil moisture sensor
// METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer
// at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml
// METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) .
#define VWC_CalcMethod 1    // Use 1 or 2
// Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface
// Default value for Decagon Devices LWS Leaf Wetness Sensor (5V power): Max. Output Voltage - 1400mV (max wetness), Min Output Voltage - 530mV (dry)
//                                                  ADC1  ADC2  ADC3  ADC4
const unsigned int AnalogSensor_MaxVoltOut[4]   = { 3000, 1400, 5000, 5000 };    // Values in miliVolt
const unsigned int AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 };
//   Enable / Disable Relay Data to Wireless Display Units  (Don't enable without an antenna attached to RF output)
#define Relay_Data       1   // 0= Disable, 1= Enable
//   Davis compatible Data Logger Settings
#define Logger_Enable    1   // 0= Disable, 1= Enable
byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30, 60 or 120)
//   Enable / Disable GPO - General Purpose Output (on boards <= v5.xx use Led+, Led- pins)
#define UseGPO           0   // 0=Disable, 1= Enable
//   Hardware settings
#define Board_Version    4     // 6 for all RX boards v6.xx, 5 for all RX boards v5.xx, 4 for all RX boards v4.xx
// ---- Define LCD I2C address
// Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display
#define LCD_I2C_Address 0x27
//   Presure Sensor Address (no need to change)
//#define BMP085_ADDRESS 0x77    // I2C address of BMP085 or BMP180
//     End of user configurable options
//   Define ID and TX unit number
#define StationID  0xA1    // Must be equal to your RX Unit (Value from 0x00 to 0xFF)
#define UnitID        0    // If you use only one TX unit define it as UnitID = 0
                           // For a second TX unit, define it as UnitID = 1
//   Define type of Temperature / Humidity sensor used as Sensor 0 and / or Sensor 1
#define TH_Sensor0  0      // [SENSOR 0] - 0 for SHT2x sensor, 1 for SHT31 sensor, 2 for HTU21 sensor, 9 for Not Used
#define TH_Sensor1  9      // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used
#define ID2  1   // Wind data
#define ID3  1   // Rain data
#define ID5  1   // Hardware Status - System Temp, Battery Voltage etc
//   Define which Temp / Hum sensor controls the fan, and threshold values
#define FanControlSensor  0      // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan)
#define fanOn_HiTemp      30      // RS Fan turn on when outside temperature is >= than this value (ºC)
#define fanOn_LowTemp     10      // RS Fan turn on when outside temperature is <= than this value (ºC)
#define fanOn_LowWind     1      // RS Fan turn on when Wind Average is <= than this value (m/s)
//   Define type of Wind Speed sensor. See below for allowed types
--- Fine Offset Anemometers ---
Use 1O for standard FO anemometers
Use 11 for FO anemometer modified with 1 hall effect sensor
--- Inspeed Anemometers ---
Use 20 for Inspeed Vortex, digital 8 pulse revolution anemometer
Use 21 for Inspeed Vortex, hall efect sensor
Use 21 for Inspeed Vortex, read switch sensor
--- Davis Anemometers ---
Use 30 for Davis 6410 anemometer
--- Novalynx Anemometers ---
Use 40 for Novalynx, model 200-WS-02F
--- Environmental Measurements Limited ---
Use 50 for EML, model WSD1
--- Didcot Instrument Company ---
Use 60 for DIDCOT, model DWR205
#define WSpeedSensor_Type 20             // SEE INFO ABOVE!!!
//   Define type of Wind Direction sensor
--- Fine Offset Wind Vane ---
Use 1O for standard FO wind vane
--- Inspeed Wind Vane ---
Use 20 for Inspeed E-Vane 2
--- Davis Wind Vane ---
Use 30 for Davis 6410 wind vane
--- Novalynx Wind Vane
--- Environmental Measurements Limited Wind Vane ---
Use 50 for EML, model model WSD1
Use 60 for DIDCOT, model DWD205
#define WDirSensor_Type  20  // SEE INFO ABOVE!!!
//          Inspeed Vane Calibration
//    Calibration values for Inspeed E-Vane 2
#define WDir_min         60
#define WDir_max        990
#define WDir_offs         0
//   Define Rain Gauge tip boucket value (mm)
  Use 0.300 for standard FineOfset rain gauges (Datasheet value = 0.2794)
  Use 0.200 for standard Davis rain gauges
#define COLLECTOR_TYPE  0.200  // Please note: Values must be in metric units. Max. resolution: 3 decimal digits
//   Soil / Leaf Interface Enable Disable
#define SoilLeaf_Interface     0   // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface
#define Number_AnalogSensors   2   // Up to 4 analog sensors
// SHT31 I2c Address
#define SHT31_address 0x44           // Default value is 0x44, but it can be changed to 0x45
//   Debug
#define Debug_Enable      false
#define DebugID0          false
#define DebugID2          false
#define DebugID3          false
#define DebugID4          false
#define DebugID5          false
#define Easyweather_Test  false
#define Debug_SLinterface false
Quote:Another important thing. If you are using the Inspeed E-Vane, the JP2 jumper on the TX board should be keep open.
Yes I left it open.
Thanks for the config files, they seem ok for the sensors you are using.
Despite it was nothing to do with the reported problem, the number format for latitude and longitude, should be an integer in tenths of degrees (based in you Config_RX.ini file, it should be: #define LATITUDE 12, #define LONGITUDE 10387)
At this point, the most probable cause of the problem is a faulty transmitter module.
If you have any of those TV / Radio pens, you could use it with the SDR sharp software and check if the transmitter is sending. An old AM radio may be enough to allow listen some beeps each time the transmitter modules sends a packet.
Anyway, replacing the transmitter module is possibly the simpler procedure.
Please keep me informed.
I have setup the TX to send only one type of data at the time:
- with only the temp/humidity, I see the LED blinking every 25 sec or so,
- with only the wind sensor, the blinking happens every 5 sec or so,
- with only the rain, it's every 30 sec.
So looks like we are good wit the TX board.
When running in test mode, the RX LED is constantly off; while in standard mode, it's always ON (supposed to be blinking, right? i dont remember).
I can see the TX LED of the RX board blinking as well.
(09-08-2016, 02:45)Werk_AG Wrote:  Anyway, replacing the transmitter module is possibly the simpler procedure.
I just replaced the receiver module on my RX, but still cannot see anything Sad
Once I was running in standard mode and go 110 during initialisation, since then, nothing more than 000.
It looks like the amplitude of the signal measured on the DATA pin of the receiver increases when I connect the antenna; makes sense though.
Not sure what else I can do - maybe change the TX transmitter to be a KDX-10036 as you specified (now it's the previous model)? I have ordered one.
Regards.
I had a faulty transmitter once. I found that it would work sometimes if I touched the coil and it's connections.
(09-08-2016, 10:23)zitoune Wrote:  I have setup the TX to send only one type of data at the time:
This shows that is the reading of the weather instruments is not blocking the system. Thanks for having tested it.
Surely the problem is with the transmitter module.
The TX LED blinking just means that the TX module is powered before it needs to send a packet, and switched off after sending it.
(09-08-2016, 12:45)uncle_bob Wrote:  I had a faulty transmitter once. I found that it would work sometimes if I touched the coil and it's connections.
The FS1000A is a good and powerful transmitter module, but it's very easy to make it not working. The coils are part of the oscillating circuit, if you inadvertently change them, by changing the space between turns, of even having a metal part close to the coils, it stops to oscillate and don't transmit anything. This was the main reason why some time ago I changed the design to use the KDX-10036 module, which don't have any coils.
As you said, sometimes touching the coils adds some capacitance to the circuit and makes it start to oscillate again. This FS1000A behaviour is widely described in several posts especially in RF forums.
I realised my RX v4 board has a KDX10036 to relay the data. So, instead of waiting for my transmitter modules to arrive by post, I actually build the new RX v5.02 (I had all the spare parts already, only re-used the HF receiver module) and used this HF emitter to replace the one of my new TX v3.12 and ... immediately it was a success! I can now receive all data on my RX Smile Thanks for your help.
I reconnected my Raspberry pi3 to CumulusMX, and everything is back to normal with this all new setup!
I'll post some pictures soon of my upgraded system.
Regards.
Great news. Thank you.
You have now an fantastic set of weather instruments, I will be waiting to see the pictures Smile
