06-09-2016, 01:35
Hi, I'm looking for thoughts on my little problem with my setup, my wireless display shows everything but the transmitted data, I set it up to use it's own TH sensor and that displays perfectly but nothing so far as the RF transmitted data. The RX unit shows the data from the TX board perfectly.
My Hardware, Wireless Display with a 20 X 4 LCD and a DHT22 sensor, I have a TFT Display coming. My TX and RX boards work perfectly as best as I can tell. My oscilloscope tests show that data is being received from the RX board on the WD boards RF receiver's Data Pin but not decoding it so I'm hoping it it's something simple that I'm overlooking.
Thanks in advance.
Terry.
Thanks in advance.
Terry.
on both Config_RX and Config_WD. It should be different from Station_ID
