OTA update error Pro2 Compact
Hi
Thought I would try the OTA upload for my Pro2 Compact. While it compiles ok it will not upload. I am getting the following error message
Arduino: 1.8.5 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Archiving built core (caching) in: C:\Users\idorm\AppData\Local\Temp\arduino_cache_906390\core\core_esp8266_esp8266_d1_mini_CpuFrequency_80,VTable_flash,FlashSize_4M1M,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_921600_47236e9164f36914b19c32380d3fdb3d.a
Sketch uses 533272 bytes (51%) of program storage space. Maximum is 1044464 bytes.
Global variables use 36780 bytes (44%) of dynamic memory, leaving 45140 bytes for local variables. Maximum is 81920 bytes.
12:05:49 [ERROR]: No Answer
I am using Python 2.7. I have can see and have set the correct port within Arduino program. Pro2 Compact is online.
Any suggestions on what the issue is would be appreciated.
Ian
Problem solved. Reset modem and then changed baud rate to 57600. Now updates Pro2 Compact without issue.
