I am getting the following error when the AQ111 initially loads.
E (4070) gpio: gpio_set_level(226): GPIO output gpio_num error
Also, the AQ111 reboots the cpu every second refresh of the PMS7003, refer towards the end of the output from the serial port I have attached. Would appear that the reset is triggered by the load error.
Am using Arduino 1.8.19 and libraries supplied.
Any assistance would be appreciated.
/code]
14:39:44.603 ->
14:39:44.603 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
14:39:44.603 -> configsip: 0, SPIWP:0xee
14:39:44.603 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
14:39:44.603 -> mode:DIO, clock div:1
14:39:44.603 -> load:0x3fff0030,len:1184
14:39:44.603 -> load:0x40078000,len:12812
14:39:44.603 -> load:0x40080400,len:3032
14:39:44.603 -> entry 0x400805e4
14:39:44.942 -> Brownout detector disabled
14:39:44.942 -> WeatherDuino 4Pro
14:39:44.942 -> Air Quality Monitor III
14:39:44.942 -> Firmware: 6.1_b012
14:39:44.942 ->
14:39:48.979 -> E (4070) gpio: gpio_set_level(226): GPIO output gpio_num error
14:39:48.979 ->
14:39:48.979 -> Connecting to zzzzzzzzzzz
14:39:49.221 -> .......
14:39:49.846 -> WiFi connected!
14:39:49.846 -> IP address: 192.168.0.228
14:39:49.846 -> MDNS responder setup correctly.
14:39:50.761 -> Get time OK.
14:39:50.761 -> UTC Time : 1767931790
14:39:50.761 -> Local Time: Friday, 09 January 2026 14:39:50
14:39:50.761 -> Reading Temp, Hum and Pressure
14:39:50.761 -> Temperature: 31.28
14:39:50.761 -> Humidity: 38.76
14:39:50.761 -> Amb. Pressure: 995.09
14:39:50.761 -> SL Pressure: 1006.65
14:39:50.761 ->
14:39:50.761 -> Setting measurement range to: 5000
14:39:50.810 -> FF,99,1,0,0,0,0,0,66,
14:39:50.810 -> 66,66
14:39:50.810 -> Measurement range changed!
14:39:53.833 -> Enabling ABC
14:40:06.871 -> Initial reading: 1
14:40:07.867 -> 80,30,27,FB,3F,30,36,FC,3F,
14:40:07.867 -> Calculated crc: D
14:40:07.867 -> Wrong reply from CO2 sensor!
14:40:07.867 ->
14:40:13.880 -> Initial reading: 2
14:40:13.880 -> FF,86,1,9A,4B,0,0,0,94,
14:40:13.880 -> Calculated crc: 94
14:40:13.880 -> CO2 RAW: 410
14:40:13.880 -> CO2 Comp: 412
14:40:13.880 -> Z19 Temp: 35
14:40:13.880 ->
14:40:19.887 -> Initial reading: 3
14:40:19.936 -> FF,86,1,9A,4B,0,0,0,94,
14:40:19.936 -> Calculated crc: 94
14:40:19.936 -> CO2 RAW: 410
14:40:19.936 -> CO2 Comp: 412
14:40:19.936 -> Z19 Temp: 35
14:40:19.936 ->
14:40:25.942 -> Initial reading: 4
14:40:25.942 -> FF,86,1,9A,4B,0,0,0,94,
14:40:25.942 -> Calculated crc: 94
14:40:25.942 -> CO2 RAW: 410
14:40:25.942 -> CO2 Comp: 412
14:40:25.942 -> Z19 Temp: 35
14:40:25.942 ->
14:40:31.948 -> Initial reading: 5
14:40:31.948 -> FF,86,1,9A,4B,0,0,0,94,
14:40:31.948 -> Calculated crc: 94
14:40:31.948 -> CO2 RAW: 410
14:40:31.948 -> CO2 Comp: 412
14:40:31.997 -> Z19 Temp: 35
14:40:31.997 ->
14:40:37.986 -> Initial reading: 6
14:40:37.986 -> FF,86,1,9A,4B,0,0,0,94,
14:40:37.986 -> Calculated crc: 94
14:40:37.986 -> CO2 RAW: 410
14:40:37.986 -> CO2 Comp: 412
14:40:37.986 -> Z19 Temp: 35
14:40:37.986 ->
14:40:43.977 -> Initial reading: 7
14:40:44.024 -> FF,86,1,9A,4B,0,0,0,94,
14:40:44.024 -> Calculated crc: 94
14:40:44.024 -> CO2 RAW: 410
14:40:44.024 -> CO2 Comp: 412
14:40:44.024 -> Z19 Temp: 35
14:40:44.024 ->
14:40:50.021 -> Initial reading: 8
14:40:50.021 -> FF,86,1,9A,4B,0,0,0,94,
14:40:50.021 -> Calculated crc: 94
14:40:50.021 -> CO2 RAW: 410
14:40:50.021 -> CO2 Comp: 412
14:40:50.069 -> Z19 Temp: 35
14:40:50.069 ->
14:40:56.055 -> Initial reading: 9
14:40:56.055 -> FF,86,1,9A,4B,0,0,0,94,
14:40:56.055 -> Calculated crc: 94
14:40:56.055 -> CO2 RAW: 410
14:40:56.055 -> CO2 Comp: 412
14:40:56.055 -> Z19 Temp: 35
14:40:56.055 ->
14:41:02.068 -> Initial reading: 10
14:41:02.068 -> FF,86,1,9A,4B,0,0,0,94,
14:41:02.068 -> Calculated crc: 94
14:41:02.116 -> CO2 RAW: 410
14:41:02.116 -> CO2 Comp: 412
14:41:02.116 -> Z19 Temp: 35
14:41:02.116 ->
14:41:08.072 -> Initial reading: 11
14:41:08.119 -> FF,86,1,9A,4B,0,0,0,94,
14:41:08.119 -> Calculated crc: 94
14:41:08.119 -> CO2 RAW: 410
14:41:08.119 -> CO2 Comp: 412
14:41:08.119 -> Z19 Temp: 35
14:41:08.119 ->
14:41:14.110 -> Initial reading: 12
14:41:14.157 -> FF,86,1,8F,4B,0,0,0,9F,
14:41:14.157 -> Calculated crc: 9F
14:41:14.157 -> CO2 RAW: 399
14:41:14.157 -> CO2 Comp: 401
14:41:14.157 -> Z19 Temp: 35
14:41:14.157 ->
14:41:20.118 -> Initial reading: 13
14:41:20.166 -> FF,86,1,8F,4B,0,0,0,9F,
14:41:20.166 -> Calculated crc: 9F
14:41:20.166 -> CO2 RAW: 399
14:41:20.166 -> CO2 Comp: 401
14:41:20.166 -> Z19 Temp: 35
14:41:20.166 ->
14:41:26.158 -> Initial reading: 14
14:41:26.207 -> FF,86,1,8E,4B,0,0,0,A0,
14:41:26.207 -> Calculated crc: A0
14:41:26.207 -> CO2 RAW: 398
14:41:26.207 -> CO2 Comp: 400
14:41:26.207 -> Z19 Temp: 35
14:41:26.207 ->
14:41:32.203 -> Init MH-Z19 Ended
14:41:32.203 ->
14:41:32.203 ->
14:41:32.203 -> Waking up the dust sensor...
14:41:32.203 -> Reading will be done 40s later.
14:41:32.203 ->
14:42:03.753 -> Reading Temp, Hum and Pressure
14:42:03.753 -> Temperature: 31.27
14:42:03.753 -> Humidity: 38.70
14:42:03.753 -> Amb. Pressure: 995.08
14:42:03.753 -> SL Pressure: 1006.64
14:42:03.753 ->
14:42:12.180 -> Fan State: 1
14:42:12.180 -> Reading the dust sensor...
14:42:12.979 -> PMS7003 valid read: 1
14:42:12.979 ->
14:42:12.979 ->
PMS7003 readings:
14:42:12.979 -> PM1.0 : 0.00
14:42:12.979 -> PM2.5 : 2.99
14:42:12.979 -> PM10.0: 3.98
14:42:12.979 ->
14:42:13.027 -> FF,86,1,8D,4B,0,0,0,A1,
14:42:13.027 -> Calculated crc: A1
14:42:13.027 -> CO2 RAW: 397
14:42:13.027 -> CO2 Comp: 399
14:42:13.027 -> Z19 Temp: 35
14:42:13.027 ->
14:42:13.027 -> CO2 1H Avg: 399
14:42:46.216 -> E (181277) gpio: gpio_set_level(226): GPIO output gpio_num error
14:42:46.554 ->
14:42:46.554 -> abort() was called at PC 0x40085797 on core 1
14:42:46.554 ->
14:42:46.554 ->
14:42:46.554 -> Backtrace:0x400842b1:0x3ffbec2c |<-CORRUPTED
14:42:46.554 ->
14:42:46.554 ->
14:42:46.554 ->
14:42:46.554 ->
14:42:46.554 -> ELF file SHA256: 0000000000000000
14:42:46.554 ->
14:42:46.554 -> Rebooting...
14:42:46.554 -> ets Jul 29 2019 12:21:46
14:42:46.554 ->
14:42:46.554 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
