Compilation Errors Rx v2.0 b011
I have tried to update the Rx board but I keep getting the following errors which I don't understand.Can someone please explain?[/quote]
Arduino: 1.6.8 (Windows 8.1), Board: "Arduino Nano, ATmega328"
In file included from sketch\WeatherDuino_Pro2_RX_v2.0_b011.ino.cpp:1:0:
C:\WeatherDuino_Pro2_v2.0_20160321\WeatherDuino_Pro2\v2.0\software\RX software\WeatherDuino_Pro2_RX_v2.0_b011\Routines.ino: In function 'void SystemInit1()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:100:38: error: invalid operands of types 'double' and 'int' to binary 'operator&'
#define lowByte(w) ((uint8_t) ((w) & 0xff))
C:\WeatherDuino_Pro2_v2.0_20160321\WeatherDuino_Pro2\v2.0\software\RX software\WeatherDuino_Pro2_RX_v2.0_b011\Routines.ino:9:30: note: in expansion of macro 'lowByte'
ExternalEeprom_write(0x0B, lowByte(LATITUDE)); // EEPROM_LATITUDE_LSB
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:101:40: error: invalid operands of types 'double' and 'int' to binary 'operator>>'
#define highByte(w) ((uint8_t) ((w) >> 8))
C:\WeatherDuino_Pro2_v2.0_20160321\WeatherDuino_Pro2\v2.0\software\RX software\WeatherDuino_Pro2_RX_v2.0_b011\Routines.ino:10:30: note: in expansion of macro 'highByte'
ExternalEeprom_write(0x0C, highByte(LATITUDE)); // EEPROM_LATITUDE_MSB
C:\WeatherDuino_Pro2_v2.0_20160321\WeatherDuino_Pro2\v2.0\software\RX software\WeatherDuino_Pro2_RX_v2.0_b011\Routines.ino:11:30: note: in expansion of macro 'lowByte'
ExternalEeprom_write(0x0D, lowByte(LONGITUDE)); // EEPROM_LONGITUDE_LSB
C:\WeatherDuino_Pro2_v2.0_20160321\WeatherDuino_Pro2\v2.0\software\RX software\WeatherDuino_Pro2_RX_v2.0_b011\Routines.ino:12:30: note: in expansion of macro 'highByte'
ExternalEeprom_write(0x0E, highByte(LONGITUDE)); // EEPROM_LONGITUDE_MSB
exit status 1
Error compiling for board Arduino Nano.
There is a note that say :
Version: : 2.0 b011 (Requires Arduino IDE 1.7.7 or newer to compile)
(08-04-2016, 13:22)laulau Wrote:  There is a note that say :
I have tried that-I have used both arduino.cc's IDE and the 1.7.8 from arduino .srl.
Hi dishlikker,
Do you have removed the previously used LiquidCrystal-I2C library and installed the new one? I'm not sure, but it seems to be the problem.
From How to upgrade WeatherDuino Pro2 Software:
- v2.0 uses a new LiquidCrystal-I2C library. Backup your existing library and delete the folder. Don’t just override your existing library.
- Copy the new LiquidCrystal-I2C library from the libraries folder included in the software package, to your Arduino libraries folder.
Users browsing this thread:
