(19-08-2015, 00:53)Werk_AG Wrote: ....also useless, including Davis, I think.
No I don't think so. Davis may use a similar sensor, but they do add the correct "Erythema Action Spectrum" filter, which perhaps explains why their sensor is so expensive (hundreds of Dollars/Euros/Pounds). See the Data Sheet
here, noting the spectral response at 360 nm, and the
logarithmic vertical scale.
Perhaps the point I'm really making is: "When (and how) does the 'UV Index' (measured at 360 nm) deviate from a number obtained by simply dividing the 'Visible Watts/m2' value by a suitable factor (in the range 100 - 120) ?". I genuinely don't know and am interested in the answer.
However, to be more positive, my own experimental "Solar Sensor" uses two channels, each with a BPW34 sensor, one "normal" (Visible + IR) and the other has an integral "IR Filter" (which actually means it is sensitive
only to IR). Comparison of the two channels has been very "interesting" to me, but is perhaps no more relevant to general "Weather Station" measurements than is (IMHO) a UV measurement at 360 nm.
But to really get back "on topic"; I have been looking at using a PTFE (Teflon) "window", to protect the sensors (particularly for BPW34 and similar devices) and also to achieve/retain a good spatial "cosine response". However, all the published data that I found referred to the "mechanical" and physical properties of PTFE,
not its optical properties. In particular, I was concerned (from various web comments and my measurements on the extremely thin "PTFE tape" used to seal water/gas pipe connections) that it might be too opaque.
So eventually, I purchased a small piece of 1 mm thick "M300 PTFE sheet" on ebay at a modest cost and can report that this sheet has an optical transmission factor (transparency) of almost exactly 50%. Thus it seems highly suitable for use as a "window" to protect any solar sensors against the elements,
and to achieve a good Cosine response from the sensor(s). But I have yet to accurately
measure the spatial response of my own sensor.
