Threads: 9
Weather Station: Darra Weather
I forgot to mention the logo. It is great and immediately suggests the new capability. Very well done.
Sorry Danner I have not had a built system to show off yet other than the scattered breadboard and wires in some of my beta testing contribution.
Hornychz: What have you used to make such neat cylindrical holes in your shield plates, and spacers to separate them. Where did you get the little case? I love the method and is what I will likely use. I have homemade my temp/humidity shield using flower pot saucers and PVC drain pipe through the center, where the sensor is installed with fan on the bottom. It does the job very well, though probably not very attractive. I plan to rebuild using a stiffer saucer plastic.
tobyportugal
Unregistered
(20-08-2017, 02:34)qldbureau Wrote: Hornychz: What have you used to make such neat cylindrical holes in your shield plates, and spacers to separate them. Where did you get the little case? I love the method and is what I will likely use. I have homemade my temp/humidity shield using flower pot saucers and PVC drain pipe through the center, where the sensor is installed with fan on the bottom. It does the job very well, though probably not very attractive. I plan to rebuild using a stiffer saucer plastic.
http://www.hellopro.fr/outil-de-coupe-en...oduit.html
http://framewareinc.com/store/matmate-ov...cle-cutter
tobyportugal
Unregistered
(24-08-2017, 18:27)hornychz Wrote:
Good evening,
Really beautiful work!
On your website, there are many inspirations to take.
http://meteo.brandysnl.cz/MyDocs/images/DSC_6833.JPG
PS: I was 2 X with Brno beginning of the Eighties (races car)
Threads: 27
Weather Station: Alma, MI USA
Thanks for posting the pictures. It helps me a lot.
Threads: 9
Thank you so much hornychz for the time taken showing your build and technique detail, you have it down to artwork. It is fantastic and spurs me on to pursue for my AQI, and rebuild my temp/humidity sheild. I really need a stiffer pot saucer than originally used.
Thank you for the links also to case supplies.
