WD v2.21 PB1 function - Printable Version
+--- Thread: WD v2.21 PB1 function (
/thread-928.html)
MikeM - 14-10-2016
What is the function of PB1 on the weather display board?
As I understand it's to switch between pages on the TFT display.
Is it still needed when using a touch TFT display?
RE: WD v2.21 PB1 function -
werk_ag - 15-10-2016
Hi MikeM,
You are right, if you are using a TFT display with touch panel, the PB1 button have no use. His functionality is automatically disabled when you set the use of the touch panel in the user configurable options.
