Radiation shield recommendations - Printable Version
+--- Forum: General Talking (
https://www.meteocercal.info/forum/Forum-General-Talking)
+--- Thread: Radiation shield recommendations (
/Thread-Radiation-shield-recommendations)
cjthomson - 18-09-2016
Hey everyone
I currently have a WD Pro 2 RX unit working with my Auriol weather station which I'm about to replace with a WD Pro 2 TX and associated sensors. So far I've got a Davis 6410 anemometer/vane and an SHT-D31 temp/humidity sensor and I plan keep using my Auriol Rain gauge.
I would like to get a radiation shield for the temp/humidity sensor and I'm looking for recommendations. In addition to a Davis 7714 I've also seen a Campbell Scientific RAD06 and RAD10 shield. Does anyone have experience of these radiation shields? Are there any others that I should take a look at?
Thanks in advance
Chris
RE: Radiation shield recommendations -
zitoune - 19-09-2016
(18-09-2016, 22:43)cjthomson Wrote: I would like to get a radiation shield for the temp/humidity sensor and I'm looking for recommendations. In addition to a Davis 7714 I've also seen a Campbell Scientific RAD06 and RAD10 shield. Does anyone have experience of these radiation shields? Are there any others that I should take a look at?
Hi Chris,
I use the Davis for a while now, I can say the construction is relatively robust. The assembly could be a bit easier though, with long screws going through the structure, but it works.
Inside you've got a bit of space to put your sensors. Actually only 3 plates are hollow, the rest are plain. It means you get little but enough space for a few sensors.
You have also different mounting options which makes it versatile.
Overall good.
JT118 - 10-11-2016
http://www.metspec.net/unaspirated-radiation-shields
These are about the best, and manufacture the campbell scientific shields you mention. The davis shields are also good,
http://www.davisnet.com/support/radiation-shield-7714/
http://www.ebay.co.uk/itm/DAVIS-RADIATION-SHIELD-STABLE-7714-PROTECTIVE-CASING-FOR-TEMPERATURE-SENSORS-/281915673545?hash=item41a37bcbc9:g:kcsAAOSwLzdWTI-y
http://www.davisnet.com/support/fan-aspirated-radiation-shield/
http://www.davisnet.com/support/solar-powered-fan-aspirated-radiation-shield-7755/
http://www.ebay.co.uk/itm/DAVIS-VANTAGE-PRO-2-RADIATION-SHIELD-ACTIVE-VENTILATION-BATTERY-SOLAR-PANEL-/351472707618?hash=item51d567e822:g:REoAAOSwyQtVv1Od
Cheaper,
http://www.ambientweather.com/amwesrpatean.html
http://www.ebay.co.uk/itm/Ambient-Weather-SRS100LX-Temperature-and-Humidity-Solar-Radiation-Shield-/152165130351?hash=item236dbfa06f:g:OmcAAOSwyDxXhTd2
And very cheap:
http://www.ebay.co.uk/itm/plastic-outer-shield-for-thermo-hygro-sensor-spare-part-for-weather-station-/121788181174?hash=item1c5b242ab6:g:5iIAAOSwhcJWH1Or
For other info,
http://www.wxqa.com/shields.html
