RX v6.00 Questions - Printable Version
+--- Thread: RX v6.00 Questions (/Thread-RX-v6-00-Questions)
RX v6.00 Questions - nskayar0 - 11-07-2016
Hi Werk_AG
I've just started to put my system together - TX, RX and WD. I have a couple of questions about the RX v6.00 board.
The Nano does not power up from the usb connector, only from the 9v source. Is this the normal operation?
What is the orientation of the 2 led's on the board?
Is there a schematic diagramme available for the RX v6.00?
Cheers - Ross
RE: RX v6.00 Questions - werk_ag - 11-07-2016
Hi Ross
(11-07-2016, 14:08)nskayar0 Wrote:  I've just started to put my system together - TX, RX and WD. I have a couple of questions about the RX v6.00 board.
Yes, that is the normal operation. The RX v6.00 board only works when powered by the external 9V power supply
(11-07-2016, 14:08)nskayar0 Wrote:  What is the orientation of the 2 led's on the board?
For both LEDs, the negative pin is the one facing the edge of the board
(11-07-2016, 14:08)nskayar0 Wrote:  Is there a schematic diagramme available for the RX v6.00?
Oops, seems I forgot to add it... I will do it right now.
