How to test if the TX board works ?? - Printable Version
+--- Thread: How to test if the TX board works ?? (
/thread-468.html)
bryce1373 - 17-02-2016
RE: How to test if the TX board works ?? -
werk_ag - 17-02-2016
After programming it, is the TX led blinking? Good sign. Unless the transmitter module is damaged, the TX unit is working.
What about the RX led in the receiver unit. It blinks too? If yes, TX is transmitting.
grunge - 18-02-2016
(17-02-2016, 04:41)Werk_AG Wrote: After programming it, is the TX led blinking? Good sign. Unless the transmitter module is damaged, the TX unit is working.
Thanks for the information, I have the TX led blinking but now to check my RX unit :-)
hornychz - 01-03-2016
TXs are working, but nothing is measured ...
werk_ag - 01-03-2016
Amazing photos, thanks. At least you still get temperature readings...
