New 4 Pro RX success - Printable Version
https://www.meteocercal.info/forum/forum-56.html)
+--- Forum: 4Pro Weather Stations - Receivers (
https://www.meteocercal.info/forum/forum-57.html)
+---- Forum: User support forum for 4Pro Weather Station Receivers (
https://www.meteocercal.info/forum/forum-61.html)
+---- Thread: New 4 Pro RX success (
/thread-2383.html)
atbukc - 28-10-2026
Just found my partially built 4 Pro RX/TX units in the back of a cupboard that have been hiding since 2022, couple of quick hours soldering and I am up and running with comms over LORA.
Really impressed with the greatly increased range and reliability so far, couple of questions so far.
1. What do the 2 LEDs labelled COMLED AND RXLED on the Rx indicate?
2. On the forecast page the times are 11:59, 14:59, etc instead of 12:00, 15:00 etc can this be fixed?
I love that I can scrape the data so easily from the units JSON interface, am currently showing this on an ESP32 e-ink display, I'll post here when the project is complete if others might be interested?
Andy
RE: New 4 Pro RX success -
werk_ag - 29-10-2026
(28-10-2026, 10:13)atbukc Wrote: Just found my partially built 4 Pro RX/TX units in the back of a cupboard that have been hiding since 2022, couple of quick hours soldering and I am up and running with comms over LORA.
Andy
Hello Andy,
I'm happy to know that even after a few years, you decided to finish the project and that everything worked out.
LoRa is a great improvement over older 433MHz versions.
1. CONLED should blink everytime there is communication with Cumulus. RXLED should blink everytime the RX receive a data pacaket from the TX unit.
2. I understand your point, but actually it isn't properly an error, initial time depends on the time first forecast was fetched, further nubers are initial time plus 3 hours. So it could happen to be 11h45, 14h45, 17h45 and so on.
Scrape the data from the unit in JSON format is a powerful for those you know what to do with them. I believe that your project of dispay the the data in a e-ink screen will be interesting for many of us, so, if you want, please fell free to share it on the forum.
Kind regards
