WeatherDuino (Local JSON) – Home Assistant Integration (v0.5.6) - Printable Version
+--- Forum: Third-party Addons (https://www.meteocercal.info/forum/forum-51.html)
+--- Thread: WeatherDuino (Local JSON) – Home Assistant Integration (v0.5.6) (/thread-2376.html)
WeatherDuino (Local JSON) – Home Assistant Integration (v0.5.6) - Sun_Dancer - 28-01-2026
Local-only Home Assistant integration for WeatherDuino devices using the built-in HTTP JSON interface – no cloud, no YAML, UI setup via Config Flow.
Supported devices:
WeatherDuino 4Pro, WeatherDisplay 4Pro, AQM2, AQM3
Features: Repository:
👉 https://github.com/Sundancer78/weatherduino-homeassistant
----old
WeatherDuino 4Pro (Local JSON) – Home Assistant Integration
I’ve released a custom Home Assistant integration specifically for the WeatherDuino 4Pro, reading sensor data locally via HTTP JSON – no cloud, no YAML configuration required.
Quote:⚠️ Important:
At the moment, this integration is tested and confirmed to work only with the WeatherDuino 4Pro.
Other WeatherDuino models may require adjustments to the JSON structure and are not yet supported.
🔧 Key Features 📊 Dashboard Examples Included All Lovelace dashboard examples (including full YAML) are documented in the repository.
📦 Installation 🔗 Repository
Feedback, issues, and pull requests are very welcome — especially from other WeatherDuino 4Pro users 😊
RE: WeatherDuino 4Pro (Local JSON) – Home Assistant Integration - uncle_bob - 31-01-2026
Thanks a great addition. Good work!
RE: WeatherDuino 4Pro (Local JSON) – Home Assistant Integration - werk_ag - 02-02-2026
Well done Sun_Dancer! Like Like Like
