Help with Arduino IDE - Printable Version
+---- Thread: Help with Arduino IDE (/thread-2372.html)
Help with Arduino IDE - sv2bzq - 17-11-2025
Hello
I downloaded your firmware for the AQMIII to start work on my current AQMIII but I get the following error :
Arduino: 1.8.19 (Windows 10), Πλακέτα:"MH ET LIVE ESP32MiniKit, 80MHz, Default with spiffs, 921600, None" In file included from C:\Users\user\Documents\Arduino\WeatherDuino_AQM_III\software\WeatherDuino_AQM_III_v6.1_b012\WeatherDuino_AQM_III_v6.1_b012.ino:39: Config_Options.h:61:1: error: 'define' does not name a type; did you mean 'rewind'? define SDC30_ELEVATION_CALIBRATION_METHOD   1   // 0= Elevation defined above, 1= Atmospheric Pressure from BME280 sensor (overrides ELEVATION) ^~~~~~ rewind In file included from C:\Users\user\Documents\Arduino\libraries\esp8266-OLED-SSD1306/SH1106Wire.h:31,                  from C:\Users\user\Documents\Arduino\libraries\esp8266-OLED-SSD1306/SH1106.h:30,                  from C:\Users\user\Documents\Arduino\WeatherDuino_AQM_III\software\WeatherDuino_AQM_III_v6.1_b012\WeatherDuino_AQM_III_v6.1_b012.ino:57: C:\Users\user\Documents\Arduino\libraries\esp8266-OLED-SSD1306/OLEDDisplay.h: In member function 'virtual bool OLEDDisplay::connect()': C:\Users\user\Documents\Arduino\libraries\esp8266-OLED-SSD1306/OLEDDisplay.h:253:29: warning: no return statement in function returning non-void [-Wreturn-type]      virtual bool connect() {};                              ^ C:\Users\user\Documents\Arduino\WeatherDuino_AQM_III\software\WeatherDuino_AQM_III_v6.1_b012\WeatherDuino_AQM_III_v6.1_b012.ino: In function 'void setup()': WeatherDuino_AQM_III_v6.1_b012:510:12: error: 'SCD30_TemperatureOffset' was not declared in this scope         if (SCD30_TemperatureOffset != 0)             ^~~~~~~~~~~~~~~~~~~~~~~ C:\Users\user\Documents\Arduino\WeatherDuino_AQM_III\software\WeatherDuino_AQM_III_v6.1_b012\WeatherDuino_AQM_III_v6.1_b012.ino:510:12: note: suggested alternative: 'SCD30_Temperature'         if (SCD30_TemperatureOffset != 0)             ^~~~~~~~~~~~~~~~~~~~~~~             SCD30_Temperature Βρέθηκαν πολλαπλές βιβλιοθήκες για "WiFi.h" Σε χρήση: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi Όχι σε χρήση: C:\Program Files (x86)\Arduino\libraries\WiFi exit status 1 'define' does not name a type; did you mean 'rewind'? Αυτή η αναφορά θα παρείχε περισσότερες πληροφορίες με "Εμφάνιση πλεονάζουσα έξοδος κατά τη σύνταξη" Επιλογή από το Αρχείο -> Προτιμήσεις.
i use it  Arduino IDE 1.8.19
Sorry but I have no knowledge at all about IDE .
Any help is welcome .
George.
RE: Compile errors AQM III - werk_ag - 24-11-2025
Hello George,
I will try to help, however if you don't have any knowledge about how to use Arduino IDE, it will be a dificult task.
First error you refer, happens because somehow first char on line 61 of the Config_Option.h file has deleted:
It should be:
#define SDC30_ELEVATION_CALIBRATION_METHOD 1
Change 1 to 0 according to: // 0= Elevation defined above, 1= Atmospheric Pressure from BME280 sensor (overrides ELEVATION)
Please try to learn something about using Arduino IDE, where to place libraries, etc, etc. There are many many tutorials on the Internet, here on the forum you may also found some no structured info.
Let me know about your progresses, I will do my best to help.
