Entry in the CumulusMX log - Printable Version
https://www.meteocercal.info/forum/Forum-Weather-Stations-Environmental-Measurement-Equipment-WeatherDuino-4Pro-Line)
+--- Forum: 4Pro Weather Stations - Receivers (
https://www.meteocercal.info/forum/Forum-4Pro-Weather-Stations-Receivers)
+---- Forum: User support forum for 4Pro Weather Station Receivers (
https://www.meteocercal.info/forum/Forum-User-support-forum-for-4Pro-Weather-Station-Receivers)
+---- Thread: Entry in the CumulusMX log (
/Thread-Entry-in-the-CumulusMX-log)
Sun_Dancer - 26-07-2023
Hello!
My Cumulus log entry contains the following lines:
2023-07-26 12:12:16.661 SendLoopCommand: Starting - LOOP 50
2023-07-26 12:12:16.662 SendLoopCommand: Sending command - LOOP 50, attempt 1
2023-07-26 12:12:16.662 SendLoopCommand: Wait for ACK
2023-07-26 12:12:16.662 WaitForACK: Starting
2023-07-26 12:12:16.677 WaitForACK: Discarding CR or LF - 0A
2023-07-26 12:12:16.677 WaitForACK: Discarding CR or LF - 0D
2023-07-26 12:12:16.695 WaitForACK: ACK received
2023-07-26 12:12:16.746 LOOP: Data - 1: 4C-4F-4F-FF-00-00-00-96-74-06-03-22-A0-02-01-01-87-00-7A-7A-A5-9D-A9-7A-9D-7A-7A-7A-7A-7A-7A-7A-7A-16-FF-FF-2B-32-21-FF-32-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-0A-02-00-00-00-00-00-00-0A-0D-C8-46
2023-07-26 12:12:16.746 LOOP: 1 - Data packet is good
I would be interested to know from whom (CumulusMX, 4Pro via RF or WifiSensors or other?) the data is requested.
greetings
RE: Entry in the CumulusMX log -
werk_ag - 26-07-2023
(26-07-2023, 13:29)Sun_Dancer Wrote: ...
That is a complex subject to explain in a post.
Please refer to Davis Vantage Serial Protocol documentation, you can find it here:
https://cdn.shopify.com/s/files/1/0515/5992/3873/files/VantageSerialProtocolDocs_v261.pdf?v=1614399559
Not always all packets within a LOOP request are received by Cumulus, not worry with that, data packets are repeated more or less every 2 seconds.
aaaaaaaaaah! So these are queries coming from Cumulus?!
werk_ag - 27-07-2023
(26-07-2023, 22:05)Sun_Dancer Wrote: aaaaaaaaaah! So these are queries coming from Cumulus?!
Yes.
