Wifi Signal Bars - Printable Version
https://www.meteocercal.info/forum/forum-56.html)
+--- Forum: Air Quality Measurement (
https://www.meteocercal.info/forum/forum-59.html)
+---- Forum: User support forum for 4Pro Air Quality Measurement equipment (
https://www.meteocercal.info/forum/forum-63.html)
+---- Thread: Wifi Signal Bars (
/thread-2179.html)
Wifi Signal Bars -
Phil23 - 29-06-2022
Noticed my Wifi Bars were missing on my display while testing.
Webpage was reporting RSSI as -55.
Would that mean all the IF statements below failed as the signal was exactly -55, not > or < ?
Bars did appear when Signal changed to -51.
Assume:-
if (rssi > -55) WiFibars = 3;
Will fix it but what will be appropriate for the other two lines?
Phil.
// Draw WiFi signal strenght on the clock display
#if (ENABLE_WIFI == 1)
void get_Wifistrength()
rssi = WiFi.RSSI();
else if (rssi < -55 && rssi > -70) WiFibars = 2;
else if (rssi < -70 && rssi > -82) WiFibars = 1;
else WiFibars = 0;
#endif
Edit:- Or would this work correctly?
rssi = WiFi.RSSI();
if (rssi >= -55) WiFibars = 3;
else if (rssi >= -70) WiFibars = 2;
else if (rssi >= -82) WiFibars = 1;
else WiFibars = 0;
#endif
RE: Wifi Signal Bars -
werk_ag - 30-06-2022
Hi Phil
Indeed it should be:
Thanks for having pointed it to me.
(29-06-2022, 07:44)Phil23 Wrote: Edit:- Or would this work correctly?
rssi = WiFi.RSSI();
else WiFibars = 0;
#endif
This will work perfectly, and its more elegant
Adopted for next release.
