BME280 not reading. - Printable Version
+---- Thread: BME280 not reading. (/thread-2176.html)
BME280 not reading. - Phil23 - 20-06-2022
Just tried Version 6.1_b010 on one of my boards & notice the BME280 is not responding.
I have 2 units & have swapped the BME's & it doesn't appear that either is faulty.
This in turn seems to throw the CO2 reading out.
Both Boards have SPS30's.
First Board has a MH-Z19, Second Board has an SCD30.
My 2nd board works fine with Both BME280's, only difference is it's configured for an SCD30 & is still on Version 6.1_b007.
This is what I see in the Serial Monitor.
This is the first time I've complied from this PC & assume the IDE is working fine.
Results of the Compile are also attached.
Cheers
Phil
09:50:16.757 -> ets Jun 8 2016 00:22:57 09:50:16.757 -> 09:50:16.757 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 09:50:16.757 -> flash read err, 1000 09:50:16.757 -> ets_main.c 371 09:50:17.132 -> ets Jun 8 2016 00:22:57 09:50:17.132 -> 09:50:17.132 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 09:50:17.132 -> configsip: 0, SPIWP:0xee 09:50:17.132 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 09:50:17.132 -> mode:DIO, clock div:1 09:50:17.132 -> load:0x3fff0030,len:1184 09:50:17.132 -> load:0x40078000,len:12812 09:50:17.132 -> load:0x40080400,len:3032 09:50:17.132 -> entry 0x400805e4 09:50:17.453 -> WeatherDuino 4Pro 09:50:17.453 -> Air Quality Monitor III 09:50:17.453 -> Firmware: 6.1_b010 09:50:17.453 -> 09:50:18.478 -> 09:50:18.478 -> Connecting to IITSNet-2G 09:50:18.571 -> 09:50:18.571 -> Brownout detector was triggered 09:50:18.571 -> 09:50:18.571 -> ets Jun 8 2016 00:22:57 09:50:18.571 -> 09:50:18.571 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 09:50:18.571 -> configsip: 0, SPIWP:0xee 09:50:18.571 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 09:50:18.571 -> mode:DIO, clock div:1 09:50:18.571 -> load:0x3fff0030,len:1184 09:50:18.571 -> load:0x40078000,len:12812 09:50:18.571 -> load:0x40080400,len:3032 09:50:18.571 -> entry 0x400805e4 09:50:18.895 -> WeatherDuino 4Pro 09:50:18.895 -> Air Quality Monitor III 09:50:18.895 -> Firmware: 6.1_b010 09:50:18.895 -> 09:50:19.916 -> 09:50:19.916 -> Connecting to IITSNet-2G 09:50:20.151 -> .. 09:50:20.243 -> WiFi connected! 09:50:20.243 -> IP address: 192.168.59.237 09:50:20.243 -> MDNS responder setup correctly. 09:50:21.679 -> Get time OK. 09:50:21.679 -> UTC Time : 1655682621 09:50:21.679 -> Local Time: Monday, 20 June 2022 09:50:21 09:50:21.679 -> Reading Temp, Hum and Pressure 09:50:22.657 -> Temperature: nan 09:50:22.657 -> Humidity: nan 09:50:22.703 -> Amb. Pressure: nan 09:50:22.703 -> SL Pressure: nan 09:50:22.703 -> 09:50:22.703 -> Setting measurement range to: 5000 09:50:22.703 -> FF,99,1,0,0,0,0,0,66, 09:50:22.703 -> 66,66 09:50:22.703 -> Measurement range changed! 09:50:25.720 -> Disabling ABC 09:50:38.722 -> Initial reading: 1 09:50:38.769 -> FF,86,1,B4,3D,0,0,0,88, 09:50:38.769 -> Calculated crc: 88 09:50:38.769 -> CO2 RAW: 436 09:50:38.769 -> CO2 Comp: 65535 09:50:38.769 -> Z19 Temp: 21 09:50:38.769 -> 09:50:44.752 -> Initial reading: 2 09:50:44.752 -> FF,86,1,B4,3D,0,0,0,88, 09:50:44.752 -> Calculated crc: 88 09:50:44.752 -> CO2 RAW: 436 09:50:44.752 -> CO2 Comp: 65535 09:50:44.798 -> Z19 Temp: 21 09:50:44.798 ->
In file included from C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306/SH1106Wire.h:31, from C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306/SH1106.h:30, from D:\Arduino\WeatherDuino_AQM_III\v6.1_b010\software\WeatherDuino_AQM_III_v6.1_b010\WeatherDuino_AQM_III_v6.1_b010.ino:57: C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306/OLEDDisplay.h: In member function 'virtual bool OLEDDisplay::connect()': C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306/OLEDDisplay.h:253:29: warning: no return statement in function returning non-void [-Wreturn-type] virtual bool connect() {}; ^ In file included from C:\Program Files (x86)\Arduino\libraries\RadioHead_v1.121\RH_LoRaFileOps.cpp:5: C:\Program Files (x86)\Arduino\libraries\RadioHead_v1.121/RH_LoRaFileOps.h:27:2: warning: #warning RH_LoRaFileOps unfinished [-Wcpp] #warning RH_LoRaFileOps unfinished ^~~~~~~ In file included from C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplayUi.h:31, from C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplayUi.cpp:27: C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplay.h: In member function 'virtual bool OLEDDisplay::connect()': C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplay.h:253:29: warning: no return statement in function returning non-void [-Wreturn-type] virtual bool connect() {}; ^ In file included from C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplay.cpp:28: C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplay.h: In member function 'virtual bool OLEDDisplay::connect()': C:\Program Files (x86)\Arduino\libraries\esp8266-OLED-SSD1306\OLEDDisplay.h:253:29: warning: no return statement in function returning non-void [-Wreturn-type] virtual bool connect() {}; ^ C:\Program Files (x86)\Arduino\libraries\SPS30-master\sensirion_hw_i2c_implementation.cpp: In function 'int8_t sensirion_i2c_read(uint8_t, uint8_t*, uint16_t)': C:\Program Files (x86)\Arduino\libraries\SPS30-master\sensirion_hw_i2c_implementation.cpp:98:36: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: Wire.requestFrom(address, count); ^ In file included from C:\Program Files (x86)\Arduino\libraries\SPS30-master\sensirion_hw_i2c_implementation.cpp:78: C:\Users\Phil.INVERELLIT\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.h:104:13: note: candidate 1: 'uint8_t TwoWire::requestFrom(int, int)' uint8_t requestFrom(int address, int size); ^~~~~~~~~~~ C:\Users\Phil.INVERELLIT\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.h:102:13: note: candidate 2: 'uint8_t TwoWire::requestFrom(uint8_t, uint8_t)' uint8_t requestFrom(uint8_t address, uint8_t size); ^~~~~~~~~~~ Sketch uses 822561 bytes (62%) of program storage space. Maximum is 1310720 bytes. Global variables use 46068 bytes (14%) of dynamic memory, leaving 281612 bytes for local variables. Maximum is 327680 bytes.
Edit:- Here's Serial Output from my 2nd unit.
10:26:21.471 -> ets Jun 8 2016 00:22:57 10:26:21.471 -> 10:26:21.471 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 10:26:21.471 -> flash read err, 1000 10:26:21.471 -> ets_main.c 371 10:26:21.842 -> ets Jun 8 2016 00:22:57 10:26:21.842 -> 10:26:21.842 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 10:26:21.842 -> configsip: 0, SPIWP:0xee 10:26:21.842 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 10:26:21.842 -> mode:DIO, clock div:1 10:26:21.842 -> load:0x3fff0018,len:4 10:26:21.842 -> load:0x3fff001c,len:1216 10:26:21.842 -> ho 0 tail 12 room 4 10:26:21.842 -> load:0x40078000,len:10944 10:26:21.842 -> load:0x40080400,len:6388 10:26:21.842 -> entry 0x400806b4 10:26:22.122 -> WeatherDuino 4Pro 10:26:22.122 -> Air Quality Monitor III 10:26:22.122 -> Firmware: 6.1_b007 10:26:22.122 -> 10:26:24.210 -> SCD30 Auto calibration set to true 10:26:24.210 -> SCD30 Current altitude: 586 Meters 10:26:24.255 -> SCD30 Current temp. offset: 0.00ºC 10:26:24.302 -> 10:26:24.302 -> Connecting to IITSNet-2G 10:26:24.489 -> ....................... 10:26:26.726 -> WiFi connected! 10:26:26.726 -> IP address: 192.168.59.238 10:26:26.772 -> Get time OK. 10:26:26.772 -> UTC Time : 1655684786 10:26:26.772 -> Local Time: Monday, 20 June 2022 10:26:26 10:26:26.772 -> Reading Temp, Hum and Pressure 10:26:26.820 -> 10:26:26.820 -> CO2 RAW: 842 10:26:26.820 -> CO2 Instant: 846 10:26:26.820 -> Temperature: 23.55 10:26:26.820 -> Humidity: 41.16 10:26:26.820 -> Amb. Pressure: 955.43 10:26:26.820 -> SL Pressure: 1021.69 10:26:26.820 -> 10:26:26.820 -> 10:26:26.820 -> Waking up the dust sensor... 10:26:26.820 -> Reading will be done 40s later. 10:26:26.820 ->
RE: BME280 not reading. - Phil23 - 20-06-2022
Swapped them around again & now both are working.
May be a bad connection on one of my 4 pin DuPont Leads.
RE: BME280 not reading. - werk_ag - 20-06-2022
(20-06-2022, 02:25)Phil23 Wrote:  May be a bad connection on one of my 4 pin DuPont Leads.
Wink
