Just tried testing a SDS011 here & don't seem to be getting a reading. - Printable Version
+---- Thread: Just tried testing a SDS011 here & don't seem to be getting a reading. (/thread-2093.html)
Just tried testing a SDS011 here & don't seem to be getting a reading. - Phil23 - 07-10-2021
At this point I have it connected to an ESP32 Dev Board.
Assume TX & RX between the sensor & ESP must be crossed, as Tx-->Tx2 & Rx-->Rx2 gives not reply in the monitor.
Just all Zeros in the replies & then Wrong reply from sensor on reading, so I assume I have it connected correctly now.
Here's what I'm seeing.
Cheers
Phil.
Edit:-
Should also add that gefore connecting I tested the SDS011 with this Windows Software & it reads fine.
https://github.com/Galch/DustViewerSharp
Not sure how old these two sensors are as I've had them in the parts box for maybe 2 years or so.
16:11:29.745 -> ets Jun 8 2016 00:22:57 16:11:29.745 -> 16:11:29.745 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) 16:11:29.779 -> configsip: 0, SPIWP:0xee 16:11:29.779 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 16:11:29.779 -> mode:DIO, clock div:1 16:11:29.779 -> load:0x3fff0018,len:4 16:11:29.779 -> load:0x3fff001c,len:1044 16:11:29.779 -> load:0x40078000,len:10124 16:11:29.779 -> load:0x40080400,len:5856 16:11:29.779 -> entry 0x400806a8 16:11:30.084 -> WeatherDuino 4Pro 16:11:30.084 -> Air Quality Monitor III 16:11:30.084 -> Firmware: 6.1_b007 16:11:30.084 -> 16:11:31.068 -> Initializing the SDS011 sensor! 16:11:31.068 -> 16:11:31.170 -> AA,C0,D6,4,FC,7,58,59,8E,AB 16:11:31.203 -> Calculate crc: 8E 16:11:31.203 -> Response crc: 8E 16:11:31.203 -> SDS011 correctly set to active report mode. 16:11:31.203 -> 16:11:32.189 -> AA,C0,D1,16,11,2D,58,59,D6,AB 16:11:32.189 -> Calculate crc: D6 16:11:32.189 -> Response crc: D6 16:11:32.189 -> SDS011 correctly set to factory working period. 16:11:32.189 -> 16:11:32.223 -> 16:11:32.223 -> Connecting to IITSNet-2G 16:11:32.459 -> ...................... 16:11:34.529 -> WiFi connected! 16:11:34.529 -> IP address: 192.168.59.48 16:11:34.733 -> Get time OK. 16:11:34.733 -> UTC Time : 1633583493 16:11:34.733 -> Local Time: Thursday, 07 October 2021 16:11:33 16:11:34.733 -> Reading Temp, Hum and Pressure 16:11:34.733 -> Temperature: nan 16:11:34.733 -> Humidity: nan 16:11:34.733 -> Amb. Pressure: nan 16:11:34.733 -> SL Pressure: nan 16:11:34.733 -> 16:11:34.733 -> 16:11:34.733 -> Waking up the dust sensor... 16:11:34.733 -> Reading will be done 40s later. 16:11:34.733 -> 16:12:14.692 -> Fan State: 1 16:12:14.692 -> Reading the dust sensor... 16:12:14.930 -> AA,C0,FA,4,DC,6,58,59,91,AB, 16:12:14.930 -> Calculate crc: 91 16:12:14.930 -> Response crc: 91 16:12:14.930 -> 16:12:14.930 -> 16:12:14.930 -> SDS011 readings: 16:12:14.930 -> PM2.5 : nan 16:12:14.930 -> PM10.0: nan
Also, the JSON URL reads like this.
{"ID":"AQM-III_Outdoor","TID":11,"ts":1633600111,"T":-1,"H":65535,"P":-1,"PM25_last":65535,"PM100_last":65535,"PM25_1H":65535,"PM100_1H":65535,"PM25_3H":65535,"PM100_3H":65535,"PM25_12H":65535,"PM100_12H":65535,"PM25_24H":65535,"PM100_24H":65535,"CO2":0}
RE: Just tried testing a SDS011 here & don't seem to be getting a reading. - werk_ag - 07-10-2021
Hi Phil,
For the connections of the SDS011 to the AQM-III board, please refer to this post:
https://www.meteocercal.info/forum/Thread-Air-Quality-Monitor-III-Overview?pid=15365#pid15365
I can't assure that the AQM-III firmware will work with other boards, however by seeing this:
I would bet you are trying to run the code without having the BME280 installed. Wink
RE: Just tried testing a SDS011 here & don't seem to be getting a reading. - Phil23 - 11-10-2021
(07-10-2021, 19:53)Werk_AG Wrote:  I would bet you are trying to run the code without having the BME280 installed. Wink
Thanks Werk,
100% correct & patched at the moment by fudging the missing Humidity to 50%.
Next step will be to begin reading the CCS811/HDC1080 Voc sensor sitting on my desk.
Seems to be plenty of examples of basic sketches to read the 811, will need to search a few to do the HDC1080 as well.
Hoping that's easy to integrate into the main code on a Copy/Paste/Edit basis of existing code blocks.
If all goes good & I get the desired result I plan to purchase another board to build an in indoor hybrid that also monitors Voc's.
Cheers
Phil.
(Expect many questions as my ESP/C+ skills are very limited).
RE: Just tried testing a SDS011 here & don't seem to be getting a reading. - werk_ag - 12-10-2021
(11-10-2021, 22:04)Phil23 Wrote:  Thanks Werk,
Wink Advantages of the open source code.
(11-10-2021, 22:04)Phil23 Wrote:  Next step will be to begin reading the CCS811/HDC1080 Voc sensor sitting on my desk.
I'm no ESP/C++ expert either, just a struggling amateur ReadManual .
Since the AQM-III does not use the CCS811/HDC1080 sensor, I suggest that the subject is not dealt with in this AQM-III support section, but in private or in this area:
https://www.meteocercal.info/forum/Forum-General-Talking--68
